Flipping dog bone mounts.
I just did a write up / pics while in progress for someone on a local board. This is a nice alternative to poly dog bone doohickeys. If you have done it kewl, i like the small difference. But if you haven't take a look.
:lol: even tho the whole mount had to come out compared to my 03 when i did this, that took me all of 15 minutes including cleanup :lol:
before
after
quick vid, easier than writing it all out for the flip
all you end up removing
what i used for tools - recommend a wrench for the passenger side or just pop a plug wire off to get the socket on.
like i said it took me all of 15 minutes, very easy job. was alot easier out of the car, i remember screwing around for an hour trying to flip them in the car on my 03
i have heard some people say it causes issues with the lower mounts... may be true but i never had any mount issues on my 03 in the 3 years after doing that flip
It's BS. It doesn't even make a big enough difference to even notice, let alone mess up the motor mounts. If that was true, I'd be blowing mounts left and right with my poly dogbone bushings.
I did this and got bad wheelhop. Flipped em back to normal and problem solved.
What does this do exactly.?
It's an alternative so to speak to buying poly dogbone mounts
:werd: it just takes a lot of the play out of the mounts. you can see the difference, normally they are allowed to move back and forth because of the way the mount is located after the 90* flip the mount is much more restricted as far as front to back movement which apparently = more TQ getting to the ground. true or not who knows i havent ever dyno'd a before and after, not sure if anyone else has either.
3 years on the 03 and no issues with me either. im not worried about it at all
the perf increase is mainly from rapid throtle inputs... and shifting. it keeps the motor from twisting as much... putting that power down to the wheels...
best way to describe it... on a slow roll you punch the gas the car lurches and then goes.... with the stiffer mounts it just goes forward no twist or lurching before the go!
the stiffer the mounts the louder the sound in the car due to extra vibration entering the car.
And that's why GM didn't do it like this from the beginning?
I remember the first time I started and drove my Lumina after putting on the FFP mounts. It was a lot noisier...and a lot more um...vibrate-y?
This was one of the first mods I did to my car!! Haven't looked back since. And haven't had any issues.
  • 4 weeks later...
