joey b Posted June 5, 2008 Report Posted June 5, 2008 Here's a 2 parter for ya. 1) The window sticks when it's half way down. This has lead to.... 2) Originally the track had pulled off of the window. I epoxied that in place and now I have a new problem. I was putting the window down and the damn motor arm pulled itself out of the window track. I've got no idea how to get that back in there. The force pulled it out. Quote
Fleeingpepper Posted June 11, 2008 Report Posted June 11, 2008 Take off the panel type thing in the back covering the cylinders and whatever else is back there, like the motor you speak of. Quote
Crazy K Posted June 11, 2008 Report Posted June 11, 2008 I should do a writeup on this. can you still completely remove the window from the car? Quote
joey b Posted June 16, 2008 Author Report Posted June 16, 2008 well it turns out that the spinning wheel that slides in the track has a crack and that was shifting it up and the bottom was popping out of the window track. I bent the track down to get it back in place and bent it back up. Quote
