cutdog12 Posted June 5, 2008 Report Posted June 5, 2008 rpm rises/surge after about 65-70 mph other than that car rides ok great summer car I would love to get issue resolved oh I forgot when it surges sometime not all the times my check engine light would come on but hen wll go off about 1 min. later . thanks for the help in advance Quote
cutdog12 Posted June 6, 2008 Author Report Posted June 6, 2008 oops!! 93 vert 3.4 cutlass supreme 110000 miles Quote
ManicMechanic Posted June 6, 2008 Report Posted June 6, 2008 Find out why the check engine light is coming on... http://www.w-body.com/forum/index.php?topic=31177.0 Quote
AWeb80 Posted June 6, 2008 Report Posted June 6, 2008 my initial guess is ICM.....from personal experience. Quote
Venom Posted June 7, 2008 Report Posted June 7, 2008 You could always spray some water around the plug boots and at the coil packs. If it starts misfiring worse, Then you might need to do a tune up. Quote
AWeb80 Posted July 1, 2008 Report Posted July 1, 2008 What Are Those? I Don't Remember Off The Top Of My Head. Quote
Breakdown Posted July 1, 2008 Report Posted July 1, 2008 I'm getting codes 32 & 34 32: EGR System: Check vacuum hoses and connections for leaks and restrictions. Replace EGR valve. 34: MAP Sensor: My heart was racing there for a second. I wasn't far off though, error codes: 32 & 44 means that the car has started it's auto-destruct sequence, not far off, I read up about this while at a car museum, something about the cold war. EGR (in my opinion) will be effected more at lower RPMs not cruising. Quote
88red4cyl Posted July 1, 2008 Report Posted July 1, 2008 My heart was racing there for a second. I wasn't far off though, error codes: 32 & 44 means that the car has started it's auto-destruct sequence, not far off, I read up about this while at a car museum, something about the cold war. What are you talking about? Quote
1990lumina Posted July 1, 2008 Report Posted July 1, 2008 I'm getting codes 32 & 34 32: EGR System: Check vacuum hoses and connections for leaks and restrictions. Replace EGR valve. 34: MAP Sensor: My heart was racing there for a second. I wasn't far off though, error codes: 32 & 44 means that the car has started it's auto-destruct sequence, not far off, I read up about this while at a car museum, something about the cold war. EGR (in my opinion) will be effected more at lower RPMs not cruising. EGR, if stuck open, will cause a huge vacuum leak at idle. Quote
