AWeb80 Posted June 5, 2008 Report Posted June 5, 2008 anyone replaced this? Mine is bad....now noticed it since I have poly dogbones and a new motor mount in......sqeaks and clunks going into gear. is it as easy a lower motor mount change? Quote
5speedz34 Posted June 5, 2008 Report Posted June 5, 2008 Its the easiest. The mount is accessible through the wheel well. Unbolt it jack up tranny and remove. Quote
MikeP2389 Posted June 5, 2008 Report Posted June 5, 2008 yea its even easier than the motor mount. Quote
AWeb80 Posted June 5, 2008 Author Report Posted June 5, 2008 Is It Solid Rubber Or Liquid Filled? Is There A Solid Option? Quote
EviLette Posted June 5, 2008 Report Posted June 5, 2008 It's a solid mount, i think thats the only way that you can get it. Quote
5speedz34 Posted June 5, 2008 Report Posted June 5, 2008 They're all solid. The ones liquid mounts is the front lower. Quote
PCGUY112887 Posted June 5, 2008 Report Posted June 5, 2008 You can get a poly version from ZZP for the 65E, which I believe uses the same mount as the 60E. http://www.zzperformance.com/grand_prix/products1.php?id=427&catid=138 Quote
PCGUY112887 Posted June 5, 2008 Report Posted June 5, 2008 Yeah it sucks, I should request more pics. I think I will actually... Quote
AWeb80 Posted June 5, 2008 Author Report Posted June 5, 2008 Well, I'm Not Paying That Much. That's A Little Over Priced I Think. Quote
MonteCarloDude Posted June 5, 2008 Report Posted June 5, 2008 You can get a poly version from ZZP for the 65E, which I believe uses the same mount as the 60E. http://www.zzperformance.com/grand_prix/products1.php?id=427&catid=138 yep, the part numbers match up. Quote
5speedz34 Posted June 6, 2008 Report Posted June 6, 2008 Well, I'm Not Paying That Much. That's A Little Over Priced I Think. A stock mount is what $40? I don't see how thats to much considering its poly. Quote
AWeb80 Posted June 6, 2008 Author Report Posted June 6, 2008 Well, I'm Not Paying That Much. That's A Little Over Priced I Think. A stock mount is what $40? I don't see how thats to much considering its poly. meh, maybe not...I picked up a solid rubber for $33 at Advance last night.....this is some hard rubber. works for me. Quote
PCGUY112887 Posted June 6, 2008 Report Posted June 6, 2008 Regardless, I got ZZP to take more pictures of the mounts! They look... odd... http://www.zzperformance.com/grand_prix/products1.php?id=427&catid=138 Quote
