alphagtp Posted June 3, 2008 Report Posted June 3, 2008 what size of belt does it takes when using that pulley? and how do I change the pulley?? I finally found one, waiting to get it in the mail !!! Quote
Andrew Posted June 3, 2008 Report Posted June 3, 2008 changing the pulley is really straight forward. as for the belt, man i cant remember. its either a 1" shorter belt or the same belt and the tensioner picks up the slack. Quote
GutlessSupreme Posted June 3, 2008 Report Posted June 3, 2008 Yea, pretty sure the FFP website called for a belt that's 1" shorter. Not sure what the stock size is, just go to a parts store and ask and get the next lowest. You need a 3-jaw or 3-bolt pulley to get the old pulley off. You'll also need a sealant to put in the keyhole (you'll see where I mean). Quote
GOT2B GM Posted June 3, 2008 Report Posted June 3, 2008 LQ1 crank pulley is easy to swap. Theres one large bolt in the center and 3 smaller bolts surrounding it. The pulley actually bolts to the harmonic balancer vs the 3.1 & 3x00 where its one piece. No key obviously. Use a 1" shorter belt. Quote
intern8tion9l Posted June 4, 2008 Report Posted June 4, 2008 mine is 1.5" shorter and still fits good. just incase there was a question Quote
GutlessSupreme Posted June 4, 2008 Report Posted June 4, 2008 LQ1 crank pulley is easy to swap. Theres one large bolt in the center and 3 smaller bolts surrounding it. The pulley actually bolts to the harmonic balancer vs the 3.1 & 3x00 where its one piece. No key obviously. Use a 1" shorter belt. damn, fine. something the DOHC guys have easier than us Quote
alphagtp Posted June 8, 2008 Author Report Posted June 8, 2008 ok working on it right now, I can't get the center bolt lose, I keeps turning, how do I get it off?? any tips? Quote
GutlessSupreme Posted June 8, 2008 Report Posted June 8, 2008 hmm. I wish I could see how the 3.4 was setup. you could try having a buddy hold the brakes while you try and crack it loose, so that the engine won't turn over (tranny in park, obviously). Quote
alphagtp Posted June 8, 2008 Author Report Posted June 8, 2008 hmm. I wish I could see how the 3.4 was setup. you could try having a buddy hold the brakes while you try and crack it loose, so that the engine won't turn over (tranny in park, obviously). tried that but nothing... Quote
alphagtp Posted June 8, 2008 Author Report Posted June 8, 2008 Impact wrench. Thats how I did mine. I don't have one... Quote
GOT2B GM Posted June 8, 2008 Report Posted June 8, 2008 buy an electric one, don't tell me you dont have electricity. Quote
CSI_MuNkY Posted June 9, 2008 Report Posted June 9, 2008 buy an electric one, don't tell me you dont have electricity. :lol: :lol: You might even be able to rent one from Home Depot or a rent-all place. Jamie Quote
z34Phoenix Posted June 9, 2008 Report Posted June 9, 2008 the way i did mine is: remove the fly wheel access cover on the trany its like one 10mm bolt holding a small plastic cover between the enigne and trany. then use a pair of vise grips to tightly clamp the flywheel... then you can turn that crank and the vise grips will hold the flywheel keeping the crank from turning. Quote
