3400 Starter Swap
Anyone have a write-up on here for replacing a starter on a 3.1?
Thanks
Yeah, its not rocket science.
Unhook battery
Remove wires from starter
remove two bolts
lower out of the way
reverse to install
I think you have to remove the flywheel cover but dont quote me on that.
Yeap, flywheel cover has to come off too, just a few extra bolts holding the plastic thingy on there. THEN unbolt power from starter, and 2 starter bolts, and off it comes. Rinse and repeat!
some applcations it is easier to remove the solenoid from the old starter before trying to wiggle the starter out.
the only other thing i had to remove was the oil filter lip. when i did mine it took me 20 minutes total
