I couldn't find a tutorial for removal of the PCM in an 04+ 3800 vehicle so I decided to make one here goes. This is not an official GM Approved way but it's how I did it and it worked.
You will need:
1/4" Nut Driver
1/2" Socket and driver
Steps:
1: Pop the hood.
2: Remove the fender brace by removing the three 1/2" bolts.
3: Locate air box
4: Unclip the airbox, remove the filter, and Unclamp and remove the MAF sensor using the 1/4 nut driver. Place out of the way.
5: Remove the filter housing by unscrewing the two bolts holding it in place. Place out of way.
6: The PCM is located inside the second portion of the airbox.
7: Do whatever you needed to do.
To Reinstall the PCM:
1: Perform steps 2-6 in reverse order making sure to put everything back where it was.
2: Close Hood
3: Wash hands. After this your hand probably look like this.
4: Start car.
I hope this helped somebody and I realize it's not perfect, maybe it cleared somebody's unspoken question if they had one.
~Brandon
