Ok, so I know I have to replace the valve cover gaskets, that's no problem, my SSEi needed it too... I need to know what else might be leaking oil... it seems like there's quite a lot of it. :thinking: I will replace the valve cover gaskets soon so I'll know if it goes away, but just as an idea of what else it might be... I would really appreciate some help. Where has your TGP been leaking oil? Thanks in advance!!!
Replace your oil pump drive seal with a GM replacement, it will be brown in color. I am willing to bet this is where you are leaking the majority of your oil from.
Also, replace your turbo oil return line, it runs from the bottom of the turbo to the oil pan. Contact TGPilot on tgpforums.com and he will hook you up with a very nice one.
Thank you...I would of never known any of that! :confused:
