RedGTP Posted May 29, 2008 Report Posted May 29, 2008 I have a BIG problem now .... http://www.youtube.com/watch?v=A0LlBEXYdy4 Durring a Road trip, I take a big hole in road... and ...after... I hear ''tock tock tock tock'' passenger side between 80-90 km/h... I stop on a side road, I check my wheel, nothing, my exausth, nothing ... I finish my roadtrip.. At my house, I jack my car .. I check .. nothing ... but when drop my car I hear this 'tock'... I grab my traillingarm just to check my bushing.. maybe .. and it'S what I find .... When my car is jacked .. didn't move, but unjacked.... it's my problem What I can do to fix this ? :S .. Weld my suport on the frame (around the hole) ??! I don't know what doing Thanks All Yann Quote
J Posted May 29, 2008 Report Posted May 29, 2008 OH SHIT, that blows. It's going to take a bit of fab work and some welding and new steel to get it to be right again. Quote
5speedz34 Posted May 29, 2008 Report Posted May 29, 2008 WOW. I've never seen that happen before. Take it to a body shop and see what they can do. Probably just the spot welds cracked. But they might have to cut into to it to get it fixed. Quote
Crazy K Posted May 29, 2008 Report Posted May 29, 2008 My 95 LQ1 cutlass sedan is the same way. mine is not worth fixing. yours... Is that heavy rusting in front of the mounting area? You should get it fixed. You will need to find someone who can weld and will be able to make good strong repairs to structural areas of cars. do you still have the Z34 parts car? If that area is still good on that car, you might be better off having a good welder use that part of that car to fix the GTP. Quote
RedGTP Posted May 29, 2008 Author Report Posted May 29, 2008 damn :S .. I do not have the Z34 since 2years. I will check this weekand what I can do with this .. :S Quote
GOT2B GM Posted May 29, 2008 Report Posted May 29, 2008 cut and weld in a new section, or try and fabricate your own custom piece. and after you get it fixed, oil spray or undercoat the hell out of your car. Quote
CSI_MuNkY Posted May 29, 2008 Report Posted May 29, 2008 Only a Canadian pothole could of done that! Damn I hate our roads... Good luck getting it fixed! Jamie Quote
BXX Posted May 30, 2008 Report Posted May 30, 2008 This is what you need. Newer W's use a bracket that bolts onto the body.. Look in the pic in the link and you will see what I am talking about http://cgi.ebay.com/ebaymotors/Century-Impala-Intrigue-Rear-Trailing-Arm-Knuckle_W0QQcmdZViewItemQQ_trksidZp1713Q2em153Q2el1262QQcategoryZ33593QQihZ013QQitemZ230203759019QQtcZphoto Quote
rockfangd Posted May 30, 2008 Report Posted May 30, 2008 that happened to my cutlass 4 years ago 4 years ago. i paid $650 to have new sections welded and they told me to get rid of the car after a year. lol 4 years later and i still have it. i undercoat it every year. The mechanic begs to differ but i told him i thought it had to do with the way he lifted my car to do the front bearings . when they did the job they replaced the driver side trailing arm and now it is bad again. Good luck Quote
Dark Ride Posted May 31, 2008 Report Posted May 31, 2008 you can get just that mount from GM for the 2nd gens for like $10 each, might be worth a shot if you could weld it in place or something Quote
RedGTP Posted May 31, 2008 Author Report Posted May 31, 2008 yes, it's may be a solution ! I will check soon.. now raining outside .. grrr Quote
RedGTP Posted June 3, 2008 Author Report Posted June 3, 2008 F**K thats SUCK ! I have take pics yesterday .... I'm desperated Quote
J Posted June 3, 2008 Report Posted June 3, 2008 looks like your going to have to cut out the rotted section and weld in a new bracket/ triangular "box" that looks to be rotted Quote
RedGTP Posted June 3, 2008 Author Report Posted June 3, 2008 I can take one in junkyard and cut in same place, and weld on my car ? Quote
J Posted June 3, 2008 Report Posted June 3, 2008 i would think so, but you'll need to leave yourself more material to work with and brace it. I'd cut as much as you can from a JY car Quote
RedGTP Posted June 4, 2008 Author Report Posted June 4, 2008 I have unbolted my trailing arm... I can make a hole and screw this support with my 'chasis' under a rear right seat Quote
