asonofabeach69 Posted May 27, 2008 Report Share Posted May 27, 2008 I recently just installed new gauges replacing my old ones, one is a trans temp and the other is oil pressure. I have no clue where the oil pressure gauge sender should go. If anyone has an oil pressure gauge please let me know where to install the sending unit end. Also where is the best place on the 4t60e to put the sender for the trans temp. Where I had it before I do not think was the most ideal spot so Im kinda hoping someone knows of an ideal spot. thanks Quote Link to comment Share on other sites More sharing options...
Hairdo12 Posted May 27, 2008 Report Share Posted May 27, 2008 If I remember correctly oil pressure is the dark brown wire going into the gage cluster. If you previously had just the low oil pressure light then you need to replace the oil pressure switch with one for a gage. It should be to the right of the oil filter. Quote Link to comment Share on other sites More sharing options...
