Addicted To Boost Posted May 27, 2008 Report Posted May 27, 2008 I just bought a new alternator that will be approximately 180-200 Amps. Will I need to upgrade my alt cable with the new higher amp alt? If so, how much bigger should I go? Thanks Quote
BXX Posted May 27, 2008 Report Posted May 27, 2008 I just bought a new alternator that will be approximately 180-200 Amps. Will I need to upgrade my alt cable with the new higher amp alt? If so, how much bigger should I go? Thanks 1/0 would be ideal for 200amp and higher... Quote
Addicted To Boost Posted May 27, 2008 Author Report Posted May 27, 2008 Ok, if it is a 180 amp, what should I run then? Sorry I don't know the exact amperage of it yet, I will be getting it tomorrow. Thanks Quote
BXX Posted May 27, 2008 Report Posted May 27, 2008 Ok, if it is a 180 amp, what should I run then? Sorry I don't know the exact amperage of it yet, I will be getting it tomorrow. Thanks 1/0 Quote
19Cutlass94 Posted May 27, 2008 Report Posted May 27, 2008 I was running 4g with my 180amp and never had a problem. Quote
Addicted To Boost Posted May 28, 2008 Author Report Posted May 28, 2008 Great, so should I run it from the alt to the remote terminal? Someone on TGPforums recommended doing that to supplement the factory wire (so I will have both cables connected). Quote
1990lumina Posted May 28, 2008 Report Posted May 28, 2008 It wouldn't hurt. Although 1 guage wire is plenty to do it on it's own IMO. Quote
19Cutlass94 Posted May 28, 2008 Report Posted May 28, 2008 Great, so should I run it from the alt to the remote terminal? Someone on TGPforums recommended doing that to supplement the factory wire (so I will have both cables connected). from the alt to the battery Quote
