Drummer Posted May 20, 2008 Report Posted May 20, 2008 my dad being the great mechanic he is tried taking apart the 5 speed that we got from the j/y, because he was wondering why there was no tranny fluid in it. Anyway he pulled the case up and it got only a little way and stopped and he couldn't pull anymore, so he tried putting it back and now it won't go back down. Has anyone ever tried taking one apart? Thanks. Quote
5speedz34 Posted May 20, 2008 Report Posted May 20, 2008 Post on 60degreeV6.com or Fiero.nl. I think there is a guy on the Chrysler forums that has taken on apart. No one on here has, I'm pretty sure you need a special jig to do it. Quote
Olds W31 Posted May 20, 2008 Report Posted May 20, 2008 A lot of jy, to meet EPA restrictions/regulations, have to "properly" remove and dispose of oil, trans fluid, etc. I did not known this until I bought a 5spd for my Protege, and noticed all three of the donor cars I was considering had loose drain plugs on the trans and no fluids. Quote
Drummer Posted May 20, 2008 Author Report Posted May 20, 2008 A lot of jy, to meet EPA restrictions/regulations, have to "properly" remove and dispose of oil, trans fluid, etc. I did not known this until I bought a 5spd for my Protege, and noticed all three of the donor cars I was considering had loose drain plugs on the trans and no fluids. Yeah i knew that, but too bad my dad didn't know that. Quote
CSI_MuNkY Posted May 20, 2008 Report Posted May 20, 2008 I have heard that you need a jig to rebuild that tranny as well. For this reason it is very costly to have them rebuilt, very few paces have a jig to do the job. I've also heard that Getrag is no longer rebuilding them, dunno how much truth there is to that though. Jamie Quote
Mr_Efficiency Posted May 20, 2008 Report Posted May 20, 2008 I have never had one apart myself but i've read a few write ups on how to do it. if you look on the inside where the throw out bearing and such is mounted there should be a black plastic circle about 3 or 4 inches in diameter, it is a plastic cover, remove it. its hard to do without breaking but the are cheap. there is some things under that cover you need to remove i forget exactly what it was, something to do with the shifter mechanism that has to be removed in order to take apart the trans. I remember seeing pictures and it was pretty obvious once the cover is off. After that you can undo the casing bolts and pull it apart. I'll see if i can find the write up for you. Heres one and another the first one is probly the best but i gave you both to keep you busy and incase the first one left anything out. I havent read through them in a while. Quote
Drummer Posted May 20, 2008 Author Report Posted May 20, 2008 Does the 282 come apart the same way as the 284? Quote
Guest Posted May 20, 2008 Report Posted May 20, 2008 Those links are for a 282, but the 284 does have the same shift-detent cover so maybe it's the same underneath. Quote
5speedz34 Posted May 20, 2008 Report Posted May 20, 2008 Similar but they are still very different transmissions. Quote
Canada Posted May 26, 2008 Report Posted May 26, 2008 The jig you are refering to is just a holding fixture to make it easier to work on........its nice, but not needed. Quote
5speedz34 Posted May 26, 2008 Report Posted May 26, 2008 The jig you are refering to is just a holding fixture to make it easier to work on........its nice, but not needed. Good to hear! I'm just reciting what I've heard from word of mouf.... Quote
