Gearhead43 Posted July 31, 2003 Report Posted July 31, 2003 One Question 1 Shawn Lin might be able to help you there On Question 2. It could be a bad relay. Quote
1uvakind Posted August 2, 2003 Report Posted August 2, 2003 i have the digital cluster on my car and it has a photo sensitive eye that is on the dash, this makes the digital cluster dim at night so it is not too bright, have you hooked this sensor up? Quote
phantomFE3 Posted August 2, 2003 Report Posted August 2, 2003 lol, laziness at its worse: too lazy to turn the headlights on at night... Quote
Panopticon Posted August 2, 2003 Report Posted August 2, 2003 how much horsepower does that mad tyte racing stripe add? Quote
Lee Posted August 2, 2003 Report Posted August 2, 2003 Dumb question but...Have you used the dimmer switch for the dash lighting. The one that when turned all the way up kicks the interior lights on. I did the UB3 cluster swap with my Regal and the cluster dims just fine with the switch. It is very bright at the higher setting so I have to turn it pretty far down to tolerate. There is a wire for the dimmer in the connector. Maybe it didn't snap in right or got put into a wrong slot. Quote
