SmoothSteve3 Posted May 18, 2008 Report Posted May 18, 2008 I know its fine to put a breather filter on the front head, but what about the one on the rear head? Would it be acceptable to put a breather filter in place of the hose that runs from the head to the upper intake (assuming I plug the upper intake of course) 3.1 1990 Lumina...FYI Quote
Addicted To Boost Posted May 18, 2008 Report Posted May 18, 2008 No.. the one on your rear valve cover would be a PCV and you don't want to disconnect that. Quote
1990lumina Posted May 18, 2008 Report Posted May 18, 2008 It would work, but I definately wouldn't do it. You'll have combustion gases and other shit that the PCV would normally redirect into the intake to be burned instead be vented externaly into the engine bay. Quote
SmoothSteve3 Posted May 18, 2008 Author Report Posted May 18, 2008 Gotcha. So why do so many people do it on the front head? Doesn't it serve the same purpose as the rear head? Quote
Addicted To Boost Posted May 18, 2008 Report Posted May 18, 2008 The one on the rear valve cover is used as a PCV. The one on the front isn't, its just a vent. Quote
z34Phoenix Posted May 22, 2008 Report Posted May 22, 2008 The two vents work in pairs... the front is the air source and the rear is the pcv side that sees engine vac... using a breather will throw off your idle fueling... in stock form the pcv is getting air mainly thru the front vent cover. this air entering the system was accounted for by the MAF sensor... if using a breather you now are injesting unmeterd hair. the offset prob wont be drastic enough to cause any issues though... Quote
GutlessSupreme Posted May 22, 2008 Report Posted May 22, 2008 His car doesn't have MAF. But that said, you still don't want to do it. Why would you want to anyway? Unless you enjoy removing your intake plenum frequently. Quote
