:cool: is there any auto part store that you guys would recommend for buy a new engine for my 94 cutlass supreme sl 3.4dohc?
:lol: :cool: so other words stick with gm, no crate. is that what i'm picking up?
well any brand new motor is going to be a crate, no matter where you get it from.
Get out the KY lube...cuz it's going to be MAJOR $$$$$$.
However I picked up a 3.1 GM crate last year for $340. It was brand new but I picked it up from somebody else who bought it from GM.
every so often a new 3.4 pops up anywhere from 900-1500
[Drops pants to ankles]
I bought a jasper motor from http://www.jasperengines.com who supposedly reman them to exceed manufacturer specs. They also give you a 75k warranty.
Installation Instructions:
PLEASE REFER TO ENCLOSED INFORMATION WHEN INSTALLING.
External oil coolers can be impossible to clean. Contamination from
a previous failure can cause debris to lodge in the original cooler.
We recommend the cooler be replaced. Proof of a cooler purchase
may be required if bearing failure occurs on your new engine.
If this application has a harmonic balancer or hub assembly that
seals against the crankshaft, Jasper recommends the balancer be
replaced or have a repair sleeve installed to prevent the potential
for front seal leaks.
Please ensure the correct length water pump bolts are installed into
the correct position. Failure to do so may damage the engine block.
Notes:
Product summary: Flat Tappets, With Balance Shaft
Block casting location: LEFT SIDE OF BLOCK AT # 3 CYL
Crank casting location: BETWEEN #5 MAIN & #6 ROD JOURNAL
Head casting location: RIGHT CORNER OF HEAD AT # 3 CYL
W/TIMING BELT
W/CAMSHAFT INTERMEDIATE DRIVE CHAIN
Core Policies:For full details of the Core Policies, click here, or call Jasper Engines & Transmissions at 1-800-827-7455.
Pricing and Availability:
The Price Is: $3763.00
Core Deposit For This Unit Is: $400.00
Skid Deposit For This Unit Is: $50.00
Sold On An Exchange Basis w/Jasper Receiving Old Unit As A Core.
:cool:not worried about the money, which crate are top of the line if any. (1) jasper
If we are talking about a 3.4 DOHC, GM hasn't made those in years.
Jasper wants $5000 to rebuild a 94+ LQ1 (I never checked on older ones). At that rate, I'd do it myself and take the individual parts to a machine shop to have them reworked.
Jamie
Oh, and they give you next to nothing for your core, $400.
Of course if the old engine if fucked, $400 is a deal, lol
Jamie
I bought a 94 crate long block motor on ebay last year, 900.00 shipped to my door in Calif.
:eek: got one from some kid for 500 bux and still rolling out the kinks in the electrical. fires on all 6 with no problems..
check the want adds in your area or condiser getting it rebuilt at machine shop. it will probably be more practial and you can custom some things with it there.
  • 1 month later...
I retract my Jasper motor endorsement.
The replacement motor started to run bad and burn coolant...uh oh... YEP, coolant is in the oil.
Replaced it with motor # 2
Motor # 2 now has a misfire on cyl 6.
Replaced injectors, plugs and wires, also checked for vacuum leaks and valid fuel pressure. The belt timing was spot on. Still hosed. Replaced EGR valve for shits and giggles, still misfired. Shop called Jasper, did a pressure test, motor # 2 is bad.
Car has been out of commission for 2 weeks and summer is slipping away. :gr_mad: :thumbsdown:
Jamie
For that price I'd pay someone to drop in an L67 and 284 and call it a day.
good luck finding someone to do that period, let alone right and for a reasonable price.
Not sure if Brian Teel still does it, but he quoted me $3500 for an entire L67 swap in the regal a couple of years ago. I forget what he charges for a 284 install, but I've heard great things about him.
Last I heard Brian Teel was still doing them... I think his time span is like 4 days or something like that...
Jamie
Yeah but the regal could be had from the factory with a 3800 not that GP.
Yeah but its a Series 1 3800, not a Series 2. You still need to convert it to OBD2 and get a new wiring harness, among a few other things.
Still doesn't matter the 1st gen w-body fits a gen 2 motor with no problem, using the stock mounts and everything. Just a few minor tweaks
