EviLette Posted May 15, 2008 Report Posted May 15, 2008 /sigh This is getting rediculous. I might as well just rip the 3.1 out while I'm at it. >.< Seriously though.. I put motor mounts in my car... not a tranny mount, hrm... a couple of weeks ago? For about two days, I had absolutely NO clunking, then I had it start again, although it has a different tone, different characteristics, and in a different place. Also, at the KC meet-n-greet we noticed that my 3.1 is sitting cockeyed (as in, its hanging lower on one side than the other.) I didn't see this until they pointed it out. Shame on me. Anyhow, the decision was a tranny mount IIRC. Pretty sure its on the driver side, and theoretically since its a mount it will be at the BOTTOM of the engine-type area. (Yes I'm being somewhat silly this morning.) Anyhow, motor mounts, after evaluating the job, ended up being something I wanted to have my mechanic do. Is it going to be the same for the tranny mount, or is this maybe something I can do on my own? Quote
19Cutlass94 Posted May 15, 2008 Report Posted May 15, 2008 The tranny mount is a million times easier to do than the motor mount. Same basic principles apply to changing the tranny mount that apply to the motor mount. Quote
ManicMechanic Posted May 15, 2008 Report Posted May 15, 2008 Block of wood on a jack under the tranny pan, unbolt mount, raise jack, slip mount out, put new in, install is reverse of removal. Quote
AWeb80 Posted May 15, 2008 Report Posted May 15, 2008 IDK If I Would Jack On The Trans Pan. It S Pretty Thin. Quote
ManicMechanic Posted May 15, 2008 Report Posted May 15, 2008 That's why I use a small sheet of plywood...Never had a dented trans pan from that. Quote
