kuntzie Posted May 12, 2008 Report Share Posted May 12, 2008 anone ever do this? im in the process and was wondering how other did it before i continue im using a bonieville heads up unit and plastic vent and HUD cover, lines up nicely in the car, appears it will need very minor work Quote Link to comment Share on other sites More sharing options...
BXX Posted May 12, 2008 Report Share Posted May 12, 2008 Should be just as simple as wiring it in like any other W-body Quote Link to comment Share on other sites More sharing options...
Venom Posted May 12, 2008 Report Share Posted May 12, 2008 I say go for it. Sounds like it should be pretty straight forward. Quote Link to comment Share on other sites More sharing options...
Euro Posted May 12, 2008 Report Share Posted May 12, 2008 I've never seen one in a 1.5 before! Quote Link to comment Share on other sites More sharing options...
Crimson Fury Z Posted May 13, 2008 Report Share Posted May 13, 2008 wiring was easy in the ol lumina. matching the hud wiring to the appropriate wires on the cluster's wiring. measure twice, cut once for the dash pad. i didn't.......... i also had to prop the rear a little to get it to show up correctly. the rear of the hud sat on top of the cluster housing, but mine was a 92, yours isn't, but expect something similar. Quote Link to comment Share on other sites More sharing options...
grandprixnyc Posted May 15, 2008 Report Share Posted May 15, 2008 It should work fine. Hardest part would be the dash modifications. The wiring is simple, hopefully someone will post the diagrams for you. Quote Link to comment Share on other sites More sharing options...
