HM282 Clutch Fork part # FOUND! (gutlass this one's for you)
back in the fall i had looked up all i needed for my 5 speed and made a list. since then we've been seeing everywhere that the HM282 clutch fork is no longer available, and no longer comes up in searches in the parts store computers.
I just cleaned my desk and found that list and looked up the # on advance auto's website. it came up as AVAILABLE!
Pioneer Products # CF136 and it is $58.99
I'm going to order one and see what happens.
BAH!@
We are sorry to inform you that the following portion of your order
currently cannot be filled:
QTY Part# Description Unit Price Total Price
1 PIOCF136 CLUTCH FORK $58.99 $58.99
We have checked multiple sources for this item, but unfortunately cannot
fill this portion of your order. Most likely, the item is out of stock
or discontinued. The item may be available in the future, but we cannot
promise it at this time. In the meantime, we will deduct the cost of the
unavailable item and ship the remainder of your order immediately. If
none
of the items you selected are available, your full order will be cancelled
and no charge will be made to your account.
Damnit! :( If only we had a GM part number, we could check VPI..
I do have 1 number and VPI shows 3 left (at $277.10 a piece :rolleyes:).. but I think it's for the 284. Does the 284 even use a fork-setup like some of the 282s do?
don't remember
i'm wondering if napa or anyone else can cross the pioneer # i've listed.
So what is the problem? Do you have an old one or is it missing altogether? My old one was bad because of the needle bearings ate the crap out of it, so I machined it down and put 6 (3 on each side) sealed ball bearings and it works awesome.
Isn't this it?
Item Number MSRP Price
23047092 $136.39 $80.85
SHAFT ASM
Looked in the 1992 parts catalog...Then on gmpartsdirect...
282's didn't have clutch forks in '92. Well, maybe, but it would be the style for the external slave setup. Thanks for checkin though.
Pat, I found this:
http://catalog.oehq.com/item.wws?sku=14092076&itempk=395300
BUT, I have that part number (14092076) listed as a "Reverse shift shaft" from an '88 GM Muncie-Getrag service manual. I almost just ordered 2 but I noticed that first. They're also listed in VPI as "Rail Shift" for ~$40 w/ 10 left in stock.
Milo, what did you use for ball bearings?
That was for 1988-89 282...1990 282 has a number of 8672427 which I couldn't find anything.
VPI: 23047092 SHAFT CLU FORK Qty: 198 $148.58
Can you confirm this is for a W-body? Or does it just give a general listing for the trans? I couldn't find that part number anywhere else but on Vintage Parts (didn't come up in search on GMPD, though I didn't go into the catalogue). Zilch on 8672427 anywhere period.
I did find this on ebay, but it appears to be for an Isuzu trans, or at least definitely one of the external-clutch-arm Getrags.
http://cgi.ebay.com/ebaymotors/8672942-Clutch-Fork_W0QQitemZ110251911570QQihZ001QQcategoryZ33693QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This was straight out of the GM parts book for W bodies. The diagram showed the fork and everything.
GMPD is where I copied what I had from my first post. :cool:
i'll have my uncle see if he can get the one jay posted for 88-89.
my backup tranny had the throwout bearing asplode massively and wipe out the arms on the fork.
Don't remember the ID, but the OD was the OD of the stock needle pieces of scheize, got a whole bunch from ebay and a friend of mine turned the fork down to the size.
