As I was comming home tonite, my 88GP 2.8L started missing bad. With the engine running I opened the hood a saw an blue arc on the I guess you may call it the electronic distributor (where all of the spark plug wires go to). Anyway, what's the correct name for it and got any idea what the part would cost? Also, I've just had new plugs and wires replaced recently and don't want to burn them up.
Thanks,
Max
Are you sure that none of your wires are loose/defective and arcing to the block? I'd check there first before looking at replacing the coil pack/s or ICM(unit underneath coils).
Yes, I've checked the wires. It looks like there's a small crack in the coil pack where it's arcing, but it's not arcing to anything metal. Just sort of "fizzes".
Max
I would change the coil packs then if one is cracked and you can see the arc. I bet that kinda looked cool though
Robby
They arent that bad, something makes me want to say like $40-60 new
Robby
