what is this?
I was looking under the hood and I saw this:
What is it, and where does it connect to?
'92 gp 3.1L
For priming and testing the fuel pump. If you apply straight power to it, the fuel pump will run regardless of key position.
sweet! I was wondering the same thing too! :lol:
You can also use that to run the pump and drain your tank for you if you have to drop the tank for whateevr reason - that is unless you're dropping the tank due to pump failure lol
I ran across that once a while back, too. Never figured out, or really cared, what it was for.
