arizlang Posted May 3, 2008 Report Posted May 3, 2008 I have a 1993 Cutlass SUpreme with the 3.4 liter V6 and lately when I've started the vehicle I get the ABS and brake lights staying on after starting. The brake lights blink 3 times and then repeat the sequence. Also my exterior lights won't come on sometimes after pushing in the switch unless I stop and start the engine several times. Any solutions would be extremely helpful before I have to take it to the stealers. Quote
Venom Posted May 4, 2008 Report Posted May 4, 2008 For the ABS youre unfortunately going to need someone with a scanner to check out the codes on it. As far as the lights, you might have a loose ground or something. Quote
GP1138 Posted May 4, 2008 Report Posted May 4, 2008 That sounds like a short or a bad ground. Do check your AUX positive post on the right strut tower though, it's sometimes the cause of funky electrical problems, which this sounds like one. Quote
arizlang Posted May 4, 2008 Author Report Posted May 4, 2008 Thanks for all your assistance ! ! ! Quote
Crazy K Posted May 4, 2008 Report Posted May 4, 2008 it if is the aux nut... I would jamb nut it, grab a nut from a donor and crank it down. Quote
