89Cutlass Posted July 29, 2003 Report Posted July 29, 2003 Ive just noticed how much crummy buildup is in my engine when i stick my finger in the oil fill or shine a light down in there theres like a 1/2in thick coating of shit built up in there what can i do to clean it because god knows whats everywhere else in the motor. Quote
phantomFE3 Posted July 29, 2003 Report Posted July 29, 2003 there is an engine powerwashing guide on Redfox340's site, heres the direct link to the guide: http://redfox340.tripod.com/wbodyperformance/id25.html hope that helps! Quote
89Cutlass Posted July 29, 2003 Author Report Posted July 29, 2003 Im talking about inside the motor not the exterior. Quote
PaPaPooh Posted July 29, 2003 Report Posted July 29, 2003 drop a quart of tranny fluid in it and let it idle for about 10 mins then change the oil that should break it all loose and come out with the oil just a seggestion anyone else want to conferm this? i don't know it anyone would suggest that? Quote
93Luminanewb Posted July 29, 2003 Report Posted July 29, 2003 I don't know if that would work.... I know I wouldn't want a quart of tranny fluid in my engine oil though... Does that actually work and not harm the engine? Quote
PaPaPooh Posted July 29, 2003 Report Posted July 29, 2003 yea it does the detergent in tranny fluid breaks the gunk up you can go with half a quart instead the only worry you have is if you drive it for a long distance or let it run to long it will harden seals if exposed to long!! Quote
89Cutlass Posted July 29, 2003 Author Report Posted July 29, 2003 I think ill just pick up a can of engine flush from advance auto parts. Quote
Redfox340 Posted July 30, 2003 Report Posted July 30, 2003 PaPaPooh is corrrect; you can run tranny fluid (15 minutes at most) to clean out the gunk inside the motor. I've personally done this myself and turn out great; tricks of a quick-lube shop. Since tranny fluid is a hydrolic detergent, it'll remove basically all build up inside. But, if you feel uncomfortable running foreign matter in your engine, I completely understand. For best results, run the flush when the engine is at running tempreture. If you used a solvent flush, make sure to flush a quart of new oil to get the solvent out. Best of luck, let us know how much falls out! - Erik Quote
gp90se Posted July 30, 2003 Report Posted July 30, 2003 run an engine flush for 5 minutes, drain it, put the plug back in, put in 3 quarts of kerocine and just let it sit for 10 minutes, dont start it just let it sit in there, drain it, flush it thru with 1 quart clean oil, drainplug back in, change the filter and put oil in. i do oilchanges for an have seen al kinds of buildup, that works 100% of the time. -Jeff Quote
NeverSayDie Posted July 30, 2003 Report Posted July 30, 2003 yeah man the ole' kero can clean alot of crap...i worked at one of those quicky lube places too, and we used it quite often Quote
paulo57509 Posted July 30, 2003 Report Posted July 30, 2003 The only risk with pouring flushing liquids into the crankcase and running the engine is that the sludge that's removed from the internal surfaces ends up down in the crankcase and can plug up the oil pump pickup screen. Quote
Robby1870 Posted July 30, 2003 Report Posted July 30, 2003 The only risk with pouring flushing liquids into the crankcase and running the engine is that the sludge that's removed from the internal surfaces ends up down in the crankcase and can plug up the oil pump pickup screen. Thats why nothing but motor oil should go into a motor. They make motor oil not motor kerosene Robby Quote
Heza Posted July 30, 2003 Report Posted July 30, 2003 on my base there is an auto hobby shop with an engine flush machine. i had crap in my motor after i came back from my deployment. got it flushed for $60. all they do for that is pump heated clean oil through the motor twice and then flush it out. it cleaned up my motor a lot. i'm sure there are other shops that do the same sort of thing. Quote
god910 Posted July 31, 2003 Report Posted July 31, 2003 Tranny fluid is simply detergent oil. A TON of people on ChevyTalk do it. They just put a quart in a day or two before they change they're oil everytime. Works like a charm. I'm gonna tell you about another odd thing to do. When you are storing an engine for a long time, start it up, and begin to pour tranny fluid into the intake (works best on carb engines) slowly at first then faster until the engine stumbles, then shut it down. It coats all the surfaces and keeps everything lubed until your ready for use. Quote
PaPaPooh Posted July 31, 2003 Report Posted July 31, 2003 a friend of mine's dad did that but he put it in the tank and drove it 4 hrs out of town it was a carberated car he said it ran with no stumbles after that Quote
GnatGoSplat Posted July 31, 2003 Report Posted July 31, 2003 Damn, what brand of motor oil do you use? I'll be sure to avoid it! Quote
89Cutlass Posted August 1, 2003 Author Report Posted August 1, 2003 Haha people have some crazy ideas Quote
Jeorge Posted August 2, 2003 Report Posted August 2, 2003 kerosene (diesel fuel) trick is an old school Trick with the old cars use to pull the coil wires so it wouldnt start then Turn the car over for about 15 sec, 2-3 times in a Row to get presure up and then let it sit then Drain Fill with 4 QT of genaric Oil say Holiday brand....then Run for couple mins then drain and add new filter and new oil of your choice.... worked on the old school cars why would it now work on the newer ones... personally I would just Go get SeaFoam additive and add that to the Gas and get a second can for the oil....I run Seafoam about every 1000 miles in my gas and works great....you will see a Gas mileage increase.. if this is your first time using Seafoam run two tank fulls in your car...then one every 1000-1500 miles.... works 50-100% better then the other additives... Quote
Slade901 Posted August 2, 2003 Report Posted August 2, 2003 I would think gas and gaskets don't mix. Quote
