patgizz Posted April 28, 2008 Report Posted April 28, 2008 hm282- 1: which cable goes to which lever on the transmission? 2: how does one bleed the hydraulic system? while the hydraulics were removed from the donor as a unit the pedal tells me there is air in the system from bouncing around in the parts car's trunk in every position other than upright as installed. the reservoir was upside down so probably got air in the MC. Quote
patgizz Posted April 28, 2008 Author Report Posted April 28, 2008 figured out and figured out. i can now depress the clutch and shift. now if i can get new turbo gaskets locally i'm good to go. Quote
intern8tion9l Posted April 28, 2008 Report Posted April 28, 2008 what gaskets are supposed to be on the turbo? i only ask cause i think i am missing something.... Quote
patgizz Posted April 28, 2008 Author Report Posted April 28, 2008 there were none on my car. they make an inlet and downpipe gaskets, and i've got evidence of exhaust leakage at both flanges so i'd like to use them when reinstalling the turbo. Quote
intern8tion9l Posted April 28, 2008 Report Posted April 28, 2008 i was thinkin you might say that. i don't have either of those either, but i have no evidence of any leakage...... Quote
Addicted To Boost Posted April 28, 2008 Report Posted April 28, 2008 There aren't gaskets on the turbo. None of the cars have them. Make sure the bolts are properly torqued down and it shouldn't leak. Quote
patgizz Posted April 29, 2008 Author Report Posted April 29, 2008 i've got black trails of leakage evidence that i'd like to eliminate. after 100k miles who knows if there is any flange warping or improper reinstallation after the crossover was replaced. Quote
