how in bloody hell did you run the tank down to bone dry 16.94 gals? Lets make sure you're getting the right numbers before troubleshooting. And yes I've warned people about using Bosch anything on GM's, especially spark plugs and O2's, the most crucial parts to engine operation. Use AC Delco or Standard Motor Products. NGK might be alright too.
I used NGK Iridiums for a while and I can definitely say I liked them. Never had any problems.
I meant to say I was referring to O2 sensors in my post. I'm running NGK v-powers in both my cars and they're doing good!
same here brah. can't go wrong for 1.75 a spark plug.
Im running the AC Delco Iridium in my 3400. The plugs only have about 8,000miles on them so there was no point in changing them.
well around here and with these high gas prices ,sometimes it gets close when it is tight. i am really bad though. i have gone 2 days on 0 bars, :rolleyes:
You actually got 16.9 gallons to fit in one fill-up? I could be below E for 30 miles and when I fill up, it might take 15.5 gals the most. You're cutting it close there!!
If your filling the filler tube, you can fit over 17gallons.
:eek: GTFO..... really?
yes sir. The gas tank shound be 16.5 gallons, and if you run it wayyy down ( like Ive been down to the point of less than 1gal ) you can fit 17gallons in there. Itll take you a while cause the pump will keep kicking back, but you can fit it if you try.
You don't want to do that though, because you'll flood your charcoal canister.
not saying you want to, but its possible...
BTW, charcoal canister?!?!?!?! BBQ?
:lol: That's what my auto shop teacher called the EVAP canister.
