Engine/Supercharger clarification questions.
I would like to know the difference between the different engine models i hear referred to on the internet for the w-bodys like whats the diff between the L67 and the L32 and mostly, whats the difference between the Series 2 and 3 3800s. I ask this because I eventually want to supercharge my n/a series 3 3800 with this Whipple Charger http://www.wbodystore.com/grandprix/animul-performance-whipple-kits-new-p-25.html
which fits the Series 2 engines. I read somewhere that series 2 S/Cs will fit the series 3 engines with use of the series 2 lower intake manifold and this is supposed to be a direct replacement for the series 2 M92 S/c.
It's a thought....
It's a thought....
If I were you I wouldn't worry about doing a Whipple as there are probably only 2 cars that have then and can get them to run right,a better option if you want big power would be a turbo.I would just do a top swap with a series 2 or 3 car and enjoy the higher compression and supercharger combo,youll be faster than stock L67/L32 cars,the Whipple will cost too much in the long run as it requires alot of tuning and you will need a race trans if you get it to work right.
This item is currently out of stock with no expected return date.
Yeah Animul's not producing that kit anymore IIRC. Since he sold both of his cars(I think) and sold his whipple set up.
