webbs Posted April 21, 2008 Report Posted April 21, 2008 Alright so i have two 12 inch subs in a box in the trunk. What i wanna do is make a panel so it looks like the trunk is just short. in other words just one piece of wood that is flush to all the edges in the trunk. what would be the best way to go about this? I really don't know how to make a template mostly. Or if anyone has done this and has dimensions or something that would be awesome. Thanks for any help. Quote
Addicted to eaton Posted April 21, 2008 Report Posted April 21, 2008 “Slick†will be the guy that you need to talk to. He does high-quality work. And he does a lot of customs installs. He can tell you every thing you need to know about stereo stuff. Quote
slick Posted April 21, 2008 Report Posted April 21, 2008 Use a large piece of cardboard, and make a template with that. Then trace it onto MDF. IMO, make it easy on yourself, can cut the larger piece in half, otherwise you will most likely never get the larger piece into the trunk. Also, another tip, leave like 1/8" gap all around, for the carpet. Otherwise, it will also make it a bear to put in also. Quote
webbs Posted April 21, 2008 Author Report Posted April 21, 2008 how would you go about making the cardboard template? just use a large piece of carcboard cut it roughly to shape and than make small adjustments? Quote
webbs Posted April 21, 2008 Author Report Posted April 21, 2008 alright ill give it a try. thanks. Quote
Psych0matt Posted April 24, 2008 Report Posted April 24, 2008 there was a guy on the cavalier boards IIRC that made a hinged one, so that he could flip it down toward the back if he needed to access anything. dunno if thats anything of interest, but might be an idea for ya Quote
