ManicMechanic Posted April 19, 2008 Report Posted April 19, 2008 VIN 1G3WT32X1SD364789 VEHICLE BUILD Merchandising Model : 3WT67 Gross Vehicle Weight Rating : 2117 kg (4668 lb) Order Number : V2X802 Build Date : 02/15/1995 Build Plant : 1SDW - DORAVILLE ASSEMBLY PLANT GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker. OPTION CODES AG1 - 6 way power seat AK5 - Inflatable Restraint, driver & passenger AN3 - Full Feature Front Bucket Seat AP9 - Trunk net AU0 - Remote Keyless Entry A90 - power locks BYP - sport equipment package B34 - Front Carpeted Floor Mats B35 - Rear Carpeted Floor Mats B84 - Body Side Moulding B9G - Production week 7 CJ2 - HVAC System, Air Conditioning, Automatic Control DG7 - Elec. mirrors DH6 - Sunvisors with ill. vanity mirrors DL5 - Decal, Roadside Service Info. DOE - Doraville, Ga assy. plant D55 - Front console D81 - Rear spoiler FE3 - Sport Suspension FE9 - Certification, Federal Emission FW9 - Final Drive Ratio - 3.43:1 IK2 - TRIM INTERIOR DESIGN (K2) JL9 - Brakes, 4-wheel antilock, 4-wheel disc K34 - Cruise control K68 - 105 amp alternator LQ1 - 3.4 DOHC MX0 - Automatic Overdrive M13 - Four Speed Electronic Automatic 3.43:1 Final NA5 - Federal Emission Standards NC5 - Dual Split Exhaust NP5 - Steering wheel, leather-wrapped rim NV7 - Steering, Power, Variable Effort (MagnaSteer) PY0 - Wheels, 16" aluminum 5-spoke style QXJ - Tires: 225/60 R16 R6Q - Control sales item 16 R7A - Control sales item 26 R7N - Control sales item 39 T86 - body color back-up lamp panel T93 - Tail and stop lamp, special UH8 - Cluster - inst, cool temp, trip odom, tach UK3 - Steering wheel controls UL0 - AM/FM Cassette (no CD) US7 - Power Antenna UW6 - SPEAKER SYSTEM, 6, DUAL F/D TWEET & WWF, DUAL EXT VH9 - ENVELOPE, OWNER INFO MAN VK3 - LICENSE PLATE, FRT MOUNTING PKG VM3 - LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH V73 - Veh Statement U.S./Canada WJ7 - Leather Seating Areas Z7S - Cutlass Supreme convertible 1SC - Merchandising option 1SZ - OPTION GROUP SAVINGS 12I - Graphite interior 16U - Bright White 41T - Black Top Last known location - Oklahoma City, OK Quote
jeremy Posted April 19, 2008 Report Posted April 19, 2008 that's interesting....where is this info from? Quote
ManicMechanic Posted April 19, 2008 Author Report Posted April 19, 2008 My records and a friend at a dealer. Quote
xtremerevolution Posted April 20, 2008 Report Posted April 20, 2008 wtf... 4668 lb? Are these things really that heavy? Holy shit... I mean, the Bonneville GXP is 3790lb... Quote
MonteCarloDude Posted April 20, 2008 Report Posted April 20, 2008 wtf... 4668 lb? omg, there is no way it can be THAT heavy. Quote
cutlassdude96 Posted April 20, 2008 Report Posted April 20, 2008 IK2-TRIM INTERIOR DESIGN (K2) DOE-PLANT CODE DORAVILLE, GA, USA Quote
theghoul Posted April 20, 2008 Report Posted April 20, 2008 12I - Graphite interior 16U - Bright White 41T - Black Top Quote
Psych0matt Posted April 20, 2008 Report Posted April 20, 2008 wtf... 4668 lb? omg, there is no way it can be THAT heavy. I'm pretty sure with a full tank and driver they are right around 3800lbs or so very cool though Quote
Hal H Posted April 20, 2008 Report Posted April 20, 2008 The GVWR is: Curb weight of vehicle (all fluids at operating levels) + # of passengers @ 175 (average) + cargo capacity of trunk (approx 200# assumption) = Gross Vehicle Weight Rating Any of you guys that have pickup trucks, look at the info sticker and you'll see GVWR ratings in the 5to6K ranges... The curb weights for 1st Gen W's (from lightest to heaviest) - this depends on equipment levels. The springs have about 10 different versions, depending on suspension, (FE1, FE2 or FE3) and the options the car was built with. The rear fiberglass springs have a 3 letter code stamped into the spring itself and you use that to match up your replacement, FYI. (had to to replace mine, and it was "FRR" or "FFR" as I remember). A/C, power seats, sunroofs, automatic tranny, and power accessories - add weight to base level models that don't have these as "standard". Also, the suspension option will have different thickness sway bars which vary in weight. Lumina (Z34's ~ 3,400 #) Cutlass Supreme Buick Regal (typically had more sound deadner on these) Grand Prix ~ 3,500-3,600# (esp. with the B4U trim) CS Convertibles ~ 3,800+# (top mechanism heavier, plus all the reinforment bracing added to body to) 4 door bodies may be a little heavier due to add'l hinge hardware, side impact beams in rear doors, additional p/w motors, window regulators, etc... Quote
Fleeingpepper Posted April 20, 2008 Report Posted April 20, 2008 OKC!? I'm gonna have to keep a lookout. I'm only about 90 mins from there, and most people who look for vehicles to buy online set it to a 100 mile radius so that OKC cars show up. Quote
slick Posted April 21, 2008 Report Posted April 21, 2008 The curb weights for 1st Gen W's (from lightest to heaviest) - this depends on equipment levels. The springs have about 10 different versions, depending on suspension, (FE1, FE2 or FE3) and the options the car was built with. The rear fiberglass springs have a 3 letter code stamped into the spring itself and you use that to match up your replacement, FYI. (had to to replace mine, and it was "FRR" or "FFR" as I remember). A/C, power seats, sunroofs, automatic tranny, and power accessories - add weight to base level models that don't have these as "standard". Also, the suspension option will have different thickness sway bars which vary in weight. Lumina (Z34's ~ 3,400 #) Cutlass Supreme Buick Regal (typically had more sound deadner on these) Grand Prix ~ 3,500-3,600# (esp. with the B4U trim) CS Convertibles ~ 3,800+# (top mechanism heavier, plus all the reinforment bracing added to body to) 4 door bodies may be a little heavier due to add'l hinge hardware, side impact beams in rear doors, additional p/w motors, window regulators, etc... Suprisingly, on these cars, the sedans are lighter than the coupes. Also, I do remember reading on here somewhere that the Z34 was one of the heaviest 1st gens as well. Quote
