blackbeauty89 Posted April 19, 2008 Report Share Posted April 19, 2008 just picked up this Z34 back panel for my monte the other day. gonna make it look a lil nicer by tinting the reverse light bar and repainting the black piece to a glossyer black. should i put some primer on before i paint it black or is the sanding good enough? i also moved "monte carlo" to the middle under the bowtie. what do you think about that? cool? i didn't glue it or anything i just placed it there to see what it looked like. Quote Link to comment Share on other sites More sharing options...
jeremy Posted April 19, 2008 Report Share Posted April 19, 2008 you shouldn't need to primer it....and I would completely debadge it Quote Link to comment Share on other sites More sharing options...
blackbeauty89 Posted April 19, 2008 Author Report Share Posted April 19, 2008 well i just night shaded my reverse bar and never would of expected this.. looks like absolute shit. what did i do wrong?? how do i fix it?? i did my tail lights with no problem Quote Link to comment Share on other sites More sharing options...
CSI_MuNkY Posted April 19, 2008 Report Share Posted April 19, 2008 What did you do in the way of prep work on that? A lot of things could of gone wrong... As for the other part you were asking if you need to primer it. That all depends on what your using for paint. Some paints will require a primer sealer, others will not. Personally I would of just buffed the shit out of it. Jamie Quote Link to comment Share on other sites More sharing options...
blackbeauty89 Posted April 19, 2008 Author Report Share Posted April 19, 2008 alright well here is a list. wet sanded it with 1500 grit wet sandpaper until the surface was smooth and that i couldn't feel any bumps cleaned it up and made sure there wasn't any dirt or anything on there put it outside in my garage and closed the door so no wind would mess things up (it's about 45 degrees idk if that would have anything to do with it) and then i just started to spray. and that was my first coat. i missed a couple spots so i hit it with a little spray. idk i'm kind of upset!! Quote Link to comment Share on other sites More sharing options...
Pontiac6KSTEAWD Posted April 19, 2008 Report Share Posted April 19, 2008 Wet sand it again, and see if it cleans up again.. Quote Link to comment Share on other sites More sharing options...
CSI_MuNkY Posted April 20, 2008 Report Share Posted April 20, 2008 How wet was your initial coat? I found nightshades to work best with 2 o 3 REALLY light coats before getting into anything heavy. Wet sand what you have and see what happens, it will either get better or you will sand through it. In which case just strip it with a paint thinner. NOT a lacquer thinner, this would eat the plastic. Your best bet is an enamel paint thinner like Varsol Jamie Quote Link to comment Share on other sites More sharing options...
jeremy Posted April 20, 2008 Report Share Posted April 20, 2008 45* temps might be a factor in that....I have never tried to use it in temps that cold. I would guess that instructions probably say use in +60* temps Quote Link to comment Share on other sites More sharing options...
j_mezz Posted April 20, 2008 Report Share Posted April 20, 2008 I wouldn't prime it if your wet-sanding didn't wear through the color coat, if it did wear through anywhere you'll see the spot through the new top coat no matter what you do. Quote Link to comment Share on other sites More sharing options...
Psych0matt Posted April 20, 2008 Report Share Posted April 20, 2008 probably too think coats. I did all my cutty lights just fine, and then tried to do my spare fogs on the TGP in the fall and it turned out like that, pretty sure because I rushed it and sprayed a ton on them Quote Link to comment Share on other sites More sharing options...
3.1cutlass Posted April 21, 2008 Report Share Posted April 21, 2008 You sprayed it too cold. I had that happen too. Make sure it is much warmer next time. Quote Link to comment Share on other sites More sharing options...
