runt Posted April 19, 2008 Report Share Posted April 19, 2008 Anyway easy way to do this on a OBD-II car without getting it up to temperature? I've got a code scanner, but I don't think that I an "make" it do it. I know on the OBD-I cars if you jump the pins they cycle. Thanks. Quote Link to comment Share on other sites More sharing options...
birdman Posted April 19, 2008 Report Share Posted April 19, 2008 turn the ac on and they should come on Quote Link to comment Share on other sites More sharing options...
1990lumina Posted April 19, 2008 Report Share Posted April 19, 2008 The Tech II can do it..not sure about other scanners. Quote Link to comment Share on other sites More sharing options...
runt Posted April 20, 2008 Author Report Share Posted April 20, 2008 turn the ac on and they should come on The left one should, but the right one shouldn't come on unless the car gets up to temp. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted April 20, 2008 Report Share Posted April 20, 2008 Why do you want to do this? Quote Link to comment Share on other sites More sharing options...
93CutlassSupreme Posted April 20, 2008 Report Share Posted April 20, 2008 For kicks? Quote Link to comment Share on other sites More sharing options...
runt Posted April 21, 2008 Author Report Share Posted April 21, 2008 Why do you want to do this? I want to be sure that the right fan is coming on when the car gets hot. As far as I know, I have NEVER heard the right side fan on. EVER. Quote Link to comment Share on other sites More sharing options...
olds cutlass Posted April 25, 2008 Report Share Posted April 25, 2008 I seem to recall seeing a switch and harness offered on a Pontiac Grandprix website that you could install and turn the fan on manually. I have thought about doing this just because the temp has to get way up there before that right fan ever comes on. Way to hot for me anyway. When setting in traffic or drivethru I will usually kick the ac on just to keep the temp from climbing up. I like for it to stay cool. I had a mechanic buddy that told me to do that because it doesnt take much heat to warp those heads. Quote Link to comment Share on other sites More sharing options...
runt Posted April 25, 2008 Author Report Share Posted April 25, 2008 That's not a bad idea...odd...but we (well...I) have Iron heads/block. Quote Link to comment Share on other sites More sharing options...
olds cutlass Posted April 25, 2008 Report Share Posted April 25, 2008 Mine is a Gen III 60 degree V6 with iron block, aluminum heads, aluminum intake, and aluminum front cover. Very important to keep an eye on the temp gauge. Thats why I keep the ac running in slow traffic or drive thru just to keep one of the cooling fans on. Quote Link to comment Share on other sites More sharing options...
93CutlassSupreme Posted April 25, 2008 Report Share Posted April 25, 2008 W-bodies, hell damn near every modern car, will not overheat, even in stop-and-go traffic, if the cooling system is operating properly. All cycling the A/C to turn on the secondary fan does is waste gasoline. AND From personal experience, 60*V6 aluminum heads do not warp as easily as claimed. Quote Link to comment Share on other sites More sharing options...
olds cutlass Posted April 25, 2008 Report Share Posted April 25, 2008 Thats fine with me with gas as cheap as it is, it only reached $3.53 hear this morning and supposed to get to $3.70 by the end of the day. I just hope it reaches $4.00 by the end of next week. Its good for the consumer, economy, its just a plus all the way around. Quote Link to comment Share on other sites More sharing options...
MonteCarloDude Posted April 25, 2008 Report Share Posted April 25, 2008 Quote Link to comment Share on other sites More sharing options...
93CutlassSupreme Posted April 25, 2008 Report Share Posted April 25, 2008 Yeah really. Quote Link to comment Share on other sites More sharing options...
runt Posted April 25, 2008 Author Report Share Posted April 25, 2008 Ugh. Why. Quote Link to comment Share on other sites More sharing options...
