Transmission- I was told the TCC wouldn’t lock up any more. But the car drives just fine if you drive it normal it seems to have a little hard shift from 1-2 around town. But if u get on the highway and trying to get up to speed it shifts fine. And at WOT it shifts fine from 1-2 only on light acceleration does it seem to shift hard.
Vacuum line to the modulator hooked up?
I'd change the fluid and filter.
I do have one Broken Vacume line.. Its right on top of the motor.
Also if its in 2ed and just puttin along around 20 and smash it. It seems hessentint to Kick down and go or to try and go in 2ed. But then it makes up its mind and kicks down.
I'd check the modulator, and fix the other borken line just for the sake of fixing it. Fluid change wouldn't hurt either.
