blugp96 Posted July 28, 2003 Report Posted July 28, 2003 Hey all, I was installing my new angeleye fog lights yesterday and I ran into a problem. I mounted them and ran all the wiring to make sure I had enough wire. I flipped the switch and everything worked. After I loomed all the wire and made it look neat, I started having problems. When I flip the switch for the main bulb to go on, all I am hearing is the relay clicking and sometimes hissing. When I flip the switch for the halo bulb, only the left one works. The fogs are wired directly to the battery, if that is any help. All of my connections are good. Any ideas??? Thanks in advance. Will Quote
Redfox340 Posted July 29, 2003 Report Posted July 29, 2003 You didn't inter-connect existing circuits, did you? The fog lights have their own relay correct? Did you run, in series, a fuse from the battery to the relay? - Erik Quote
Baddflash Posted July 29, 2003 Report Posted July 29, 2003 Sounds like a ground problem or there's a problem with the relay. Quote
blugp96 Posted July 29, 2003 Author Report Posted July 29, 2003 Redfox: No, Yes, and Yes I think I have a bad relay, but I am not sure. Quote
