ManicMechanic Posted April 17, 2008 Report Posted April 17, 2008 1994 Cutlass Supreme 3.4 DOHC 3 wire, Orange, green and tan near the A/C compressor. Thanks... Quote
slick Posted April 17, 2008 Report Posted April 17, 2008 Almost looks like it'd go to the coils, but then again, with the plug being that oily, maybe a low oil level sensor, or an oil pressure sensor plug? Quote
ManicMechanic Posted April 17, 2008 Author Report Posted April 17, 2008 All those are plugged in, car runs fine and everything seems to be working, no SES light. Quote
Psych0matt Posted April 17, 2008 Report Posted April 17, 2008 fan? where does it start, or come from, maybe I can take a look at mine and check it out Quote
ManicMechanic Posted April 17, 2008 Author Report Posted April 17, 2008 Comes out of the harness that runs up to the computer, it's in the same harness as the fans, but both fans are plugged in and working. I appreciate that Matt. Quote
slick Posted April 17, 2008 Report Posted April 17, 2008 Hmm.... Isn't there a plug on the radiator? Quote
ManicMechanic Posted April 17, 2008 Author Report Posted April 17, 2008 Just the low coolant sensor...Which is broken but plugged in. Quote
Psych0matt Posted April 17, 2008 Report Posted April 17, 2008 I bet it's the blinker fluid guage. Those started in '94 IIRC. I'll go take a look, but it's dark out and I don't have use of the garage right now Quote
ManicMechanic Posted April 17, 2008 Author Report Posted April 17, 2008 LOL! I'm looking through the FSM and coming up with nothing... My friend that got the harness from my parts car seems to have disappeared... Quote
Psych0matt Posted April 17, 2008 Report Posted April 17, 2008 I see one, but I can't feel where it goes since it's still hot. If I was looking at the right one, it comes out of the loom and runs between the exhaust mani and the starter, slightly more toward the drivers side, and I think it plugged into the block? Again, the engine is still hot and it's dark out, but i couldnt see it from the top or bottom really Quote
slick Posted April 17, 2008 Report Posted April 17, 2008 I bet it's the blinker fluid guage. Those started in '94 IIRC. That's not it. Don't you remember, the blinker fluid reservoir is under the front drivers seat. Quote
Psych0matt Posted April 17, 2008 Report Posted April 17, 2008 I bet it's the blinker fluid guage. Those started in '94 IIRC. That's not it. Don't you remember, the blinker fluid reservoir is under the front drivers seat. Oh, right right. Muffler bearing camber adjustment monitoring guage? Quote
ManicMechanic Posted April 17, 2008 Author Report Posted April 17, 2008 Just went out and took a closer look, found where it went. And my A/C compressor has a massive leak...There's $20 for freon down the drain. The compressor I got from gpchris leaks, this one leaks, I have one left before I give the hell up and get a new one. Quote
Psych0matt Posted April 17, 2008 Report Posted April 17, 2008 Just went out and took a closer look, found where it went. Whassat? Quote
Andrew Posted April 17, 2008 Report Posted April 17, 2008 yeah inquiring minds want to know. and are you sure its the compressors leaking and not a line/connection? Quote
DavidHowell3633 Posted April 23, 2008 Report Posted April 23, 2008 Looks like the 24x crankshaft position sensor wiring connector. (CKP) Quote
ismellrealbad Posted April 23, 2008 Report Posted April 23, 2008 um, where did that go...thats looks like a mystery plug i had. Quote
