Guest RedCutlassSL Posted July 28, 2003 Report Posted July 28, 2003 Any ideas on how to remove these rusted fuckers? Quote
AWeb80 Posted July 28, 2003 Report Posted July 28, 2003 Any ideas on how to remove these rusted fuckers? I'm not sure where they are, but when I have to deal with rusted bolts, I first try WD-40 and let it sit for a few minutes. If that doesn't work. Wipe it off (WD-40 is flamable) and use a torch, get it warm(not red hot, just short of hardly glowing), crank on it with a wrench, ratchet (whatever suits the situation better). While cranking on it, tap it with a hammer. Best of luck! Quote
Intlcutlass Posted July 28, 2003 Report Posted July 28, 2003 I know exactly what your going through.... I just did mine. I didn't have a problem with the bolts on the knuckle , BUT , where those arms attach to the body (forward of the wheels a bit) was a PITA. I had to use a grinder. I cut the old arm off (I was replacing the arms) , right up where the bolt goes through, that only took a second, THEN I took the grinder to what was left of that arm/bolt. I cut that in half, then it took a bit of twisting, pulling and more twisting....... you have my pity...... Quote
