89SupremeCutty Posted April 15, 2008 Report Share Posted April 15, 2008 this weekend im gonna go to one of the u-pull yards and get new gauges. right now i have the base cluster in my lumi, the one without the tach. if i got one from a monte with column shift or a lumi with the tach gauges that also had column shift, would it be a direct swap? i also have been looking at some reverse glow gauges that i like. i found one i really like, but i can't get it if i get the cluster with the tach: i alos like this one: but my dilemma is that i have column shift and it dosn't show the gear indicator. does anyone know of any sites that sells them for the 95-99 lumina/monte? Quote Link to comment Share on other sites More sharing options...
logikf1ve Posted April 15, 2008 Report Share Posted April 15, 2008 Yes, it is a direct swap. Just make sure if you have a 95-96, you get it from a 95-96. The other years will work, but your fuel gauge will not. I went through this before when I swapped one into my '95. I believe it is then 97-98 and then 99-01 (00-01 for Luminas only, Monte doesn't apply) To play it safe, though, I recommend getting it ONLY from the same year car. Also, that's the only problem with the glow gauges, you either have no indicator, or the indicator, but no tach. At least that's the way it is with the eBay glow gauges. Quote Link to comment Share on other sites More sharing options...
89SupremeCutty Posted April 15, 2008 Author Report Share Posted April 15, 2008 that's what i've seen from the ebay ones too. i have a 98 so i'll definately make sure it comes from the same year. what's different between the years that the fuel gauge dosn't work? Quote Link to comment Share on other sites More sharing options...
logikf1ve Posted April 15, 2008 Report Share Posted April 15, 2008 Fuel pump, mostly. Quote Link to comment Share on other sites More sharing options...
89SupremeCutty Posted April 16, 2008 Author Report Share Posted April 16, 2008 thanks for the info. i'll update as soon as i get a new cluster. maybe this weekend. Quote Link to comment Share on other sites More sharing options...
