I plan on almost tucking the wheel or having it about 1/4" from the fender. The rims I have are only 7" wide so I shouldnt have much of a rubbing issue
Well, after a phone call with A1Racing where they forgot to call and tell me the sleeves I ordered were outta stock, I was able to find out a few things
1- Held gets their sleeves and adjuster nuts from A1Racing
2- Held uses 5" sleeves that are a larger OD that what I though
3- Those 5" sleeves are cheaper than the ones I originally ordered and will be slightly loose enough to swap over onto new struts when needed
I should have the sleeves and adjuster nuts on Thrusday. I already have the QA1 springs from Summit. I need to order the ES spring isolators from Advance Auto, and I have my steel plate to do the mounts and I have almost completed them
Naw, the 5" tubes will be just fine... It will also allow for plenty of ground clearence from what I understand...
5"ers should be fine. I ran both of my GP's w/o a mount in between the coil and the stocker and I never had a spring unload. The only problem I had was the spring not seating perfect (a little creaking) when I would put the car on a lift. All I would have to do was turn the spring a little or just put it up and down a couple times and no creaking. That was moreso w/ my 91 than my 96. If you don't fell comfortable doing it that way, I don't blame you. I do think there is less of a problem that way than w/ the FFP coilovers, though. A helper spring would have eliminated the improper seating, though, I'm sure.
