noise in front suspension
Guest TurboSedan
every time i crank the wheel and go over a bump (slow speed), i get a noise coming from the front strut assembly somewhere. it's like a popping sound, it only does it twice or so and it's definately not a CV shaft noise. it's been going on since i got the lowering springs put in. any ideas? i'm pulling the springs out soon and chopping 1/4 coil off, and installing KYB's, so maybe i'll get a better idea when i get it all apart. anything in particular i should look for?
joshua
check your ball joints and tie rod ends....mine did this and went away after replacing them.
Guest TurboSedan
thanks, i'm gonna pull the wheels off and give them a close look. i should probably just have them replaced anyway, considering the cars mileage (almost up to 180,000 miles).
joshua
