I'm still getting an ABS Light even after replacing the Wheel Senors. They are a High failure part. Do I need someone with an ODB-I computer to reset this or something. I used my tool on the ALDL Port. And All I get is the 12 (Diagnostic) Code so the Regular ECM is clear. or is there a separate connector that I'm not seeing?
:willynilly:
Car is a 1994 with 122K 3.1L Auto/OD
This isn't as much of a pain in the Butt job as it looks BTW.
good luck. I think you can only get ABS codes with a tech 1 scanner.
check and macke sure:
that the aux battery post is tight
that ALL brake lights work, including with the left and right, and hazard blinkers are on.
check the fuse
all good?
