Night Fury Posted April 9, 2008 Report Posted April 9, 2008 So today was my first day under my CS. WOAH. EVERYTHING is covered in... something. Every bit of the bottom of the engine, the front, sides and BOTTOM of the tranny, and there is even a sling line. I know for a fact that the two tranny lines to the radiator are leaking at the radiator, but that is not related. The reason I am concerned is it all looks relatively fresh. AND all of the fluid levels are good! Its crazy. What the F is making the mess? Quote
Night Fury Posted April 9, 2008 Author Report Posted April 9, 2008 What tranny do I have anyways? It doesn't say on the pan like the Ciera's does. Quote
1990lumina Posted April 9, 2008 Report Posted April 9, 2008 Just Hydramatic on your pan I bet, same as my Lumina. Anyway, like Maniac said above, those are your two options. Did you also check your power steering fluid? When mine blew I had oil everywhere (although you'd know soon as it doesn't take much fluid loss for the pump to start making noise and the steering to get harder) Quote
Night Fury Posted April 9, 2008 Author Report Posted April 9, 2008 Just Hydramatic on your pan I bet, same as my Lumina. Anyway, like Maniac said above, those are your two options. Did you also check your power steering fluid? When mine blew I had oil everywhere (although you'd know soon as it doesn't take much fluid loss for the pump to start making noise and the steering to get harder) Well, maybe. There is a bit of a squeak, but the steering is not hard at all. I may just add some. It was full to the C mark... Would it REALLY cover everything under the sun like that tho? Including the entire bottom of the engine+tranny? 4T60...or 440T4. how do I find out? Quote
Euro Posted April 9, 2008 Report Posted April 9, 2008 you run through some tar? and find the RPO code on the car, that should tell you. Quote
GP1138 Posted April 9, 2008 Report Posted April 9, 2008 I guarantee the car has the 4T60 in it. The 440T4 is the same. Quote
Night Fury Posted April 9, 2008 Author Report Posted April 9, 2008 So.... What color should PS fluid be? What is currently in there looks a lot like tranny fluid. What I used to fill it up was crystal clear. Quote
Euro Posted April 9, 2008 Report Posted April 9, 2008 PS fluid is a reddish color. Kinda like clean trans fluid Quote
Night Fury Posted April 9, 2008 Author Report Posted April 9, 2008 Well the new Valvoline 75Kmi+ PS fluid is brake fluid clear. weird. Quote
1990lumina Posted April 9, 2008 Report Posted April 9, 2008 To be honest power steering fluid could be ANY color from my experience this winter. I used some that was beer color, red like tranny fluid color, and finally the good stuff - AC Delco Cold Climate fluid which is green. Quote
ismellrealbad Posted April 9, 2008 Report Posted April 9, 2008 If you have that bad of a leak or combination of leaks it doesnt matter where its coming from or what color it is cuz its covered in over grime. It blows further back and all over everything from driving. Get a couple cans of degreaser and your garden hose and go to town (just watch for neighbors), then keep checking it periodically to see if you can get a better idea of what it is. If i had to gues your oil pan gasket is probably leaking along with the other leaks you mentioned. Quote
wildbill Posted April 10, 2008 Report Posted April 10, 2008 If you have that bad of a leak or combination of leaks it doesnt matter where its coming from or what color it is cuz its covered in over grime. It blows further back and all over everything from driving. Get a couple cans of degreaser and your garden hose and go to town (just watch for neighbors), then keep checking it periodically to see if you can get a better idea of what it is. If i had to gues your oil pan gasket is probably leaking along with the other leaks you mentioned. That what I recommend also. Just clean it up and watch to see where the leaks occur. Keep an eye on your fluids too. If you can pinpoint what kind of fluid it is and still cannot locate the leak; then add some dye and use a blacklight to see where it is coming from. Quote
digitaloutsider Posted April 10, 2008 Report Posted April 10, 2008 Well the new Valvoline 75Kmi+ PS fluid is brake fluid clear. weird. You put power steering fluid in your transmission? Quote
Night Fury Posted April 10, 2008 Author Report Posted April 10, 2008 Well the new Valvoline 75Kmi+ PS fluid is brake fluid clear. weird. You put power steering fluid in your transmission? What?!?! no. Quote
Schurkey Posted April 11, 2008 Report Posted April 11, 2008 If you have that bad of a leak or combination of leaks it doesnt matter where its coming from or what color it is cuz its covered in over grime. It blows further back and all over everything from driving. True. Get a couple cans of degreaser and your garden hose and go to town (just watch for neighbors) Better yet--head for the spray-it-yourself high-pressure car wash. Warm water mixed with detergent and delivered at high velocity. Perfect. Drive the car up on ramps when you get there, so you can also spray from underneath. (and you also leave the mess at the car wash, not in your driveway.) Quote
