pwmin Posted April 9, 2008 Report Posted April 9, 2008 I have a kenwood _____-X791 and the AUX is much quieter than the radio/cd/etc. Is there a volume adjustment to change that like on my old JVC KD-AR5500 or am I SOL? Yes, I have my archos turned all the way up. I can't find anything in the manual and companies are usually a PIA to get any answers from, so I thought I would ask you guys. Quote
slick Posted April 9, 2008 Report Posted April 9, 2008 Nope, nothing. An auxilary input will generally be quiter, as it is only an analong input. Quote
pwmin Posted April 9, 2008 Author Report Posted April 9, 2008 Nope, nothing. An auxilary input will generally be quiter, as it is only an analong input. will the USB port be louder? i guess I could just get an adapter and use that. I guess I could also convert the rear output thingy with that adapter you showed me before. Quote
GP1138 Posted April 9, 2008 Report Posted April 9, 2008 Most decks with an AUX input allow you to adjust the level the deck receives before it's output. Quote
pwmin Posted April 9, 2008 Author Report Posted April 9, 2008 looks like that cable runs off aux, too Most decks with an AUX input allow you to adjust the level the deck receives before it's output. my JVC did, but I can't find anything on this deck that would allow that. Quote
slick Posted April 10, 2008 Report Posted April 10, 2008 Yeah, from all of the Kenwood's I've ever used, there are no Audio level adjustments for the Aux. Inputs, IIRC. Check the Menu in Standby mode just to be sure, but I don't think there is. Quote
pwmin Posted April 17, 2008 Author Report Posted April 17, 2008 Yeah, from all of the Kenwood's I've ever used, there are no Audio level adjustments for the Aux. Inputs, IIRC. Check the Menu in Standby mode just to be sure, but I don't think there is. WRONG! well, sort of. there is actually a level adjustment (just found it) and it is in standby mode. IDK why I didn't see this reply earlier, but it's all good now. I just need to set up of the G-meter yet. Quote
slick Posted April 17, 2008 Report Posted April 17, 2008 Hey see, thats why I told you to check the Menu! I can't remember everything! Quote
pwmin Posted April 17, 2008 Author Report Posted April 17, 2008 Hey see, thats why I told you to check the Menu! I can't remember everything! LOL but you should Quote
GP1138 Posted April 17, 2008 Report Posted April 17, 2008 Most decks with an AUX input allow you to adjust the level the deck receives before it's output. This guy is awesome!! Glad you got it sorted out. Quote
pwmin Posted April 18, 2008 Author Report Posted April 18, 2008 Most decks with an AUX input allow you to adjust the level the deck receives before it's output. This guy is awesome!! Glad you got it sorted out. Quote
