DavidHowell3633 Posted April 9, 2008 Report Posted April 9, 2008 My driver's door doesn't fit tight. How do you adjust the door? Thanks Quote
Psych0matt Posted April 9, 2008 Report Posted April 9, 2008 loosen the lower two bolts on the car side, shift door, tighten lower two bolts Quote
Crazy K Posted April 9, 2008 Report Posted April 9, 2008 please elaborate. is the door sagging as well as not being tightly shut? the striker and/or the latch mechaism on the door can be adjusted if the door is just not sealing tight. make sure that some of the items like the guide pins are not holding the door from closing further. if the door is sagging... fix the sagging first before adjusting the latch, otherwise you'll just be wasting time.. Quote
Psych0matt Posted April 9, 2008 Report Posted April 9, 2008 Ken is smart, listen to what it says. What I said is mostly for adjusting the window/seal gap or whatever Quote
DavidHowell3633 Posted April 9, 2008 Author Report Posted April 9, 2008 The door was sagging, but, my friends down at the body shop adjusted that by adding some shims. If you look at the door from the rear wheel it does not appear to meet the body tightly. I don't get wind noise or water from the window so the weatherstripping is doing a good job. the door itself just doesn't fit tight. I'll check the alignment pin. I do remember seeing some brass flakes and pin misalignment scrapes when I first bought the car. That could be it? Thanks. Quote
DavidHowell3633 Posted April 10, 2008 Author Report Posted April 10, 2008 Alignment pin looks ok. Still unsure how to adjust door to close tightly. Thanks Quote
Crazy K Posted April 10, 2008 Report Posted April 10, 2008 see the striker? the pin on the car body? with a torx head bolt? loosen that and move it inward. Quote
GP1138 Posted April 10, 2008 Report Posted April 10, 2008 loosen the lower two bolts on the car side, shift door, tighten lower two bolts I did this today and it worked very well, for the most part. My problem is the window frame up top does not want to be against the body like it should. I'm watching this thread with bated breath! Quote
Psych0matt Posted April 10, 2008 Report Posted April 10, 2008 loosen the lower two bolts on the car side, shift door, tighten lower two bolts I did this today and it worked very well, for the most part. My problem is the window frame up top does not want to be against the body like it should. I'm watching this thread with bated breath! On the Vert DVD we got with the pin cup kit, it has a video for repairing convertibles, and it's like three hours long. I watched a good portion of it, and the section dealing with leaks and such said to do exactly that. However, if that's not the reason for adjusting the door, it may not be the best place to start Quote
Crazy K Posted April 10, 2008 Report Posted April 10, 2008 john, your door is badly damaged still and needs replaced. the damage on your coupe is bad enough that the top has bent outward. I would simply grab the top of the door and pull inward while holding the rest of the door open. do that a couple of times and the door top will bend inward and should seal better. Quote
93CutlassSupreme Posted April 10, 2008 Report Posted April 10, 2008 Bend a door with your bare hands? Damn... Quote
GP1138 Posted April 11, 2008 Report Posted April 11, 2008 john, your door is badly damaged still and needs replaced. the damage on your coupe is bad enough that the top has bent outward. I would simply grab the top of the door and pull inward while holding the rest of the door open. do that a couple of times and the door top will bend inward and should seal better. This is pretty much my game plan. I figure if I break anything beyond repair, I'm out a damaged door, and it will prove much easier to enter and exit my Cutlass! Quote
Addicted to eaton Posted April 11, 2008 Report Posted April 11, 2008 Bend a door with your bare hands? Damn... Yeah lol, When i did it I stood in between the door and car and press my knees on the door as i pulled back on the door usin my body weight Quote
DavidHowell3633 Posted April 12, 2008 Author Report Posted April 12, 2008 Crazy K- I loosened the striker pin a couple of months ago and it didn't budge. I was stumped. I suppose I'll spray some PB Blaster and use my mallet to persuade it toward the inside. As far as door glass adjustment, I have seen on several cars (I dunno about the W-body) that if you'll take the door panel off and look toward the bottom of the rear channel you may find a bolt with a slotted head for a screwdriver. You would loosen a lock nut and turn counter-clockwise to move the bottom of the channel toward the outside which also angles the top toward the inside. Anyway, my Haynes manual refers to something similar on Page 11-8, 15. "Door window glass- removal installation, adjustment". Since this was most likley written for a non-convertible it will not be exact. If you need more from my Haynes manual let me know and I'll type it up for you. Quote
