Still no speedo or odometer...need help!
Well Im just about completely out of ideas, my speedo and odometer do not operate, they havent since I got the car. Well so far i have replaced the instument cluster, that was not the problem, they i replaced the VSS (what a pain) that did not fix the problem. We also checked the connections at the computer and there seems to be no issues there. Well late tonight we observed next to none voltage going to the cluster harness in slot C5 (dark green wire) which seems to be the appropriate one for the speedo. now Im basically stumped, it could be an internal computer problem or a cut in the wire somewhere between the cluster and the ecm right? could it be something else...maybe. the whole thing is driving me nuts. Well anyways if anyone can help me with this situation please do so, any ideas on how i can solve this aggravation would be great. Im tired of process of elimination! it costs me too much money! :frown:
i would think it might be a broken wire someplace, either between where the vss plugs in and the computer, or between the computer and instrument cluster. i don't think it's the computer itself. that's all i can think of at this hour that might be wrong.
Yeah, I'd do a continuity test on those two lengths of wire.
I would probly do a voltage test on the wires, that go to the VSS, and see if the voltage coming out of the VSS changes while driving. if that does change, then find the same wire at the computer, and check for the same thing again. If the voltages, or milivots, change, check also the same thing at the back of the cluster. Sooner or later you will find a place where the voltages dont move while driving. Go back to the last place you checked, and work your way to the point where you didnt get voltage change, and you will find it, and can fix it.
You dont have to physically be driving the car. Put the front end up on jack stands, with the parking brake set, or a block in front and back of the wheels.
This sucks Id imagine following the lengths of these wires is like navigating a labryinth :mad:
So if I understand this correctly, the 2 wires out of the VSS should be the same 2 wires into the computer? So do I test voltage at the computer side or the VSS side. I dont mean to sound ignorant but man its all frustrating, and just so I understand clearly I know its a dark green wire from the cluster to the computer and Its a yellow and purple wire from the sensor to the computer, right? So I pretty much going to test the wires from the sensor to the computer first because that is the shortest distance and then work from there.
thanks for all the help.
I am not entirely sure on that one. I had to do this on a Cavalier, and the computer is in the cabin, I am not sure if it splits off, or what, with a W-body.
Your PCM should be located in the engine bay p/s side under a fairly larger black cover in front of the overflow tank, if I'm correct and assuming you haven't already gotten that far :lol: Too bad its not OBD2, you could just hoop up a scan too and see if the PCM is getting a signal and skip that step.
PS, props to another jersey guy on the board.
WHAT YEAR OF CAR AND WHAT MOTOR AND TRANS?
If it is a 93... does the car shift gears as it is supposed to when driven, if it has the E tranny?
if so, then the pcm is getting the vss signal.
to try a test... unplug the vss and see if you see a difference or total lack of shifting fromnthe trans.
1993 3.4L LQ1 4T60E, Im probably gonna get back at it this weekend and figure out whats goin on :confused:
ok. simple question: does the tranny shift by itself at all in the D or OD gears?
yea the tranny shifts fine by itself in OD and D
then you could have...
break in the wiring to the cluster. might be a wiring pin that has backed out. the VSS wire is green.
corrupted ecm chip (someone here had one that made the say it was doing 120 when they did like 75... but it also speed governed the car as if it was going that fast at 75.
bad pcm?
the first is most likely. the pcm has to be getting a speed signal to shift.
bad pcm?
very true ken. how is it supposed to shift without a speed signal :high5:
thanks for all the imput guys, im thinking one of the possible areas for a break in the wire is behind the radio, when i bought the car there was a aftermarket headunit in the car (that i since replaced) whoever put that radio in may have caused a break in the wire. The speedo hasnt worked at all since ive owned the car.
why dont you replace the speedo from one in the junkyard? just a thought. could it be your instrument panel isnt working right?
already did that, that was my first move lol :biggrin:
well, sorry man, i got nothing for you. you could pull off the radiator cap and put a new car underneath it :willynilly:
got a digital voltmeter? do a continuity check on the green vss wire from the pcm to the cluster. I might be able to get those pinouts....
:high5: lol i wish i would have thought of that originally
Just a thought, maybe the wheel speed sensor?
isnt that essentially the same thing as a vss? maybe i am wrong
Wheel Speed Sensors are part of the ABS system and shouldn't have anything to do with the speedometer.
gotta be a broken wire or short to ground from the ecm to the cluster. that's all i can think of.
