xxXRandyyXxx Posted July 27, 2003 Report Posted July 27, 2003 i replace the fuse for my dashboard in my 89' cutlass supreme int atleast every 2 days. Sometimes I have to replace it 3 times in a row before it blows again. Any suggestions? Quote
Guest Anonymous Posted July 27, 2003 Report Posted July 27, 2003 Check all exterior lights. See if you have one that's loose,has a bad connection,has a crack in it or is on one day and off the next. I had a car once that did that. Turned out to be a rear turn signal/brake light bulb was coming out of the socket. The grease was dried up and the bulb had got wet. If I hit a bump hard enough to jolt the bulb, out went the dash. Replaced the bulb and added some grease and never blew another fuse. Quote
