ihateallmustangs Posted April 6, 2008 Report Posted April 6, 2008 I'm still going to "tweak" the fittiment a bit and I have a bug to work out , The reading flashes ZERO. I got it from the yard so I could very well be broken. I have read a few times of 2ndgen owners having a problem with the display flashing "0" at all times. Quote
MonteCarloDude Posted April 7, 2008 Report Posted April 7, 2008 That looks awesome good job man! x2, that looks great. Quote
runt Posted April 7, 2008 Report Posted April 7, 2008 If I'm not mistaken, you have to repin some of the connections to get it to display right for your '96. Quote
ihateallmustangs Posted April 7, 2008 Author Report Posted April 7, 2008 If I'm not mistaken, you have to repin some of the connections to get it to display right for your '96. I re-wired the entire thing to the newer plug Quote
ZoomZoomFan Posted April 8, 2008 Report Posted April 8, 2008 Your check engine light is on. Looks good man. Quote
5speedz34 Posted April 8, 2008 Report Posted April 8, 2008 Ya, take care of your check engine light first noob! Quote
AWeb80 Posted April 8, 2008 Report Posted April 8, 2008 I doubt it Tony....only OBD II and above Quote
Addicted to eaton Posted April 8, 2008 Report Posted April 8, 2008 Has to obd2 But u can still make most of it work. Like doors, TCS ...(as 2ed gear start) Quote
Scottster Posted April 8, 2008 Report Posted April 8, 2008 So are you guys that are doing this keeping the DIC on the left side of the dash, or is that non-existant? That would look cool, with digital displays on both sides. I'd assume you could have them both set to different settings, so more information is being displayed at once (as in one set to outside temp for example, and the other with fuel economy readings). Quote
Addicted to eaton Posted April 8, 2008 Report Posted April 8, 2008 I don't know about him. It makes you feel pretty bad ass when you sit in my car all the stuff to look at. It remindes me of a airplain the one that belongs in my car shows me everything, Out side temp, mpg, range. Then the one on the right is for 2ed gear start, showing me if its on or off. For my low tire pressure. And for washer fluid low or not, What door is open of if my trunk is open. All pretty cool stuff that you dont need lol. Quote
ihateallmustangs Posted April 8, 2008 Author Report Posted April 8, 2008 I have a colling fan problem which is why my engine light is on , I could not find a 1996 DIC and any I did find on ebay they want crazy $$$ for it. So this is better anyway! Quote
pontiacmaniac94 Posted April 23, 2008 Report Posted April 23, 2008 i really wish my car was OBDII.....i would sooo do the swap for that DIC....they look soo tight! i want more pictures! Quote
grandprixnyc Posted May 4, 2008 Report Posted May 4, 2008 Looks good! Can we get an overall shot of the whole ensemble now? Quote
ihateallmustangs Posted May 19, 2008 Author Report Posted May 19, 2008 Got a new DIC which happend to be from a 97. IMO the best suited for these cars. Of coarse working condition. Quote
MonteCarloDude Posted May 20, 2008 Report Posted May 20, 2008 that fits in there perfect x2, thats looks great. Quote
ihateallmustangs Posted May 20, 2008 Author Report Posted May 20, 2008 Awesome, how many of the functions work? Everything except for "oil life" and "check tire pressure light". Quote
ihateallmustangs Posted May 20, 2008 Author Report Posted May 20, 2008 No way of wiring that up? Possibly yeah , I have yet to even try Quote
BXX Posted May 20, 2008 Report Posted May 20, 2008 The check tire pressure I know for a fact runs off the ABS system. So you would have to have the appropiate ABS and BCM... Which you dont.. The oil life system runs off the PCM, but 1st gen PCMs dont have the programming for it... Quote
GP1138 Posted May 20, 2008 Report Posted May 20, 2008 That dash looks weird! My old '95 didn't have an engine symbol in place of the SES light, and it didn't have those fuel indicators under the lines either. Special '96 dash?? Quote
