KrazyCutlass1995 Posted July 27, 2003 Report Posted July 27, 2003 i was thinking its about time for my tranny fluid and filter to be changed , i dont know how long ago this has been since it has last been done either =/ ... and i was wondering if it would be ok if i was to use some synthetic tranny fluid such as b&m trick shift ? i run pretty hard at times and dont wanna break anything ... or should i stick to something like maxlife ? my tranny i think has same as motor which is about 152k miles... thanks Quote
Redfox340 Posted July 27, 2003 Report Posted July 27, 2003 With that many miles and no history of service, I would aviod sythetic / syn blends all together at this moment. I would drop the pan in this situtation and change the filter instead of a flush. Once the pan drop is completed and driven for about 10K miles and see no deteriation of the tranny, then go ahead and do a complete flush. - Erik Quote
KrazyCutlass1995 Posted July 27, 2003 Author Report Posted July 27, 2003 at that point in time use syn ? or normal fluid? if it works like it should after 10k miles Quote
Redfox340 Posted July 27, 2003 Report Posted July 27, 2003 After the pan drop, and everything still turing, then you can consider a semi-synthetic fluid after 10K. The only reason for synthetic better wear properties at a newer tranny age. It's better (like motor oil) when its in it's prime... if there are ANY leaks, they'll increase due to smaller molecule size. - Erik Quote
KrazyCutlass1995 Posted July 27, 2003 Author Report Posted July 27, 2003 o aight , coo thanks bro =) cant weight to do my 20w50 syntec oil change this next week .... i think ill hold off on the tranny for now Quote
Redfox340 Posted July 27, 2003 Report Posted July 27, 2003 o aight , coo thanks bro =) cant weight to do my 20w50 syntec oil change this next week .... i think ill hold off on the tranny for now 20W - 50? :shock: Planning on racing @ 5500 RPM's all day in 90* degree sunny heat? A little think for my blood unless your pushrod leaks from every seal imageable. - Erik Quote
KrazyCutlass1995 Posted July 27, 2003 Author Report Posted July 27, 2003 lol yea untill i get my cutty's overheating problems fixed i need something that will withstand really high temps in stop and go traffic ... since i live in florida its so damn hot naturaley ... i race once in a while with rpms around 4500 to 5k as well so its all good Quote
mdelorie Posted July 28, 2003 Report Posted July 28, 2003 I used some B&M at about 200 000 kms.. and it caused nothing but trouble... slipping like mad... it was awful. I got it flushed and the problem disappeared. Stick to the GM stuff. Quote
KrazyCutlass1995 Posted July 28, 2003 Author Report Posted July 28, 2003 cool , thanks alot .... no harm by running this kinda oil tho right? lol Quote
mdelorie Posted July 28, 2003 Report Posted July 28, 2003 as in permanent damage? I don't think so, since the tranny's been fine after I got rid of the B&M stuff. But I singlehandedly blame it for all my transmission trouble. Quote
KrazyCutlass1995 Posted July 28, 2003 Author Report Posted July 28, 2003 damn b and m hahah thanks man Quote
mdelorie Posted July 28, 2003 Report Posted July 28, 2003 Woops... just relized you were talking about the engine oil. :oops: Well.. 20W50 seems awful thick. But I'm in Canada. Quote
Robby1870 Posted July 29, 2003 Report Posted July 29, 2003 Well.. 20W50 seems awful thick. But I'm in Canada. Yeah, thats very thick, 10W-30 is the way to go, 5W-30 is recommended by GM Robby Quote
