Crank Position Sensor Replacment - Location?
Where is the CPS located on the 92 lumina z34?
anyone have any pictures?
do i get at it from the top or bottom of the car?
And does anything need to be removed to replace it or get to it?
thanks
I find it best to remove the plenum and get to it from the top...But I have skinny arms and that helps...
I will assume that it is an automatic car...
If so the best way I have found is to remove the alternator and get at it from that side, i have skinny arms and small hands but I do not recall being able to get at it from the top with the plenum removed, I could be wrong however.
I do it like this too. But the problem is you can't reach down in between there, and stick your face down there to see what your doing at the same time. It's a touchy-feely thing for sure.
