shadow Posted April 10, 2008 Author Report Posted April 10, 2008 Please anyone? Go on TGPforums and make a topic asking "Dogbone" there. I know he has a step-by-step with pics. No I changed the dogbones fine I was asking about the lower motor mount. Quote
Addicted To Boost Posted April 10, 2008 Report Posted April 10, 2008 No the guys name is dogbone! Quote
EviLette Posted April 10, 2008 Report Posted April 10, 2008 Just roll your creeper under the car. The motor mounts are essentially huge chunks of rubber with a little metal attached. If the rubber looks warped, cracked, dry, or otherwise NOT good.. your mounts are probably bad. I have two of them to get done on my car... seriously doubt I can change out my own motor mounts though. Quote
shadow Posted April 10, 2008 Author Report Posted April 10, 2008 No the guys name is dogbone! Oh Quote
shadow Posted April 10, 2008 Author Report Posted April 10, 2008 Just roll your creeper under the car. The motor mounts are essentially huge chunks of rubber with a little metal attached. If the rubber looks warped, cracked, dry, or otherwise NOT good.. your mounts are probably bad. I have two of them to get done on my car... seriously doubt I can change out my own motor mounts though. Thanks oh I thought there was just one mount under the car... Quote
EviLette Posted April 10, 2008 Report Posted April 10, 2008 There are two that I am sure of... they are in the rear, so maybe tranny mounts? IDK, I'm not super-techincal on this stuff. I think there might actually be three under there, possibly four. I was looking at my brakes the last time my car was on a lift, so I don't really remember. Just roll your creeper underneath, and anything that sits between the motor/tranny and the subframe (or connects them) that involves a chunk of rubber is probably a motor mount. Quote
shadow Posted April 10, 2008 Author Report Posted April 10, 2008 There are two that I am sure of... they are in the rear, so maybe tranny mounts? IDK, I'm not super-techincal on this stuff. I think there might actually be three under there, possibly four. I was looking at my brakes the last time my car was on a lift, so I don't really remember. Just roll your creeper underneath, and anything that sits between the motor/tranny and the subframe (or connects them) that involves a chunk of rubber is probably a motor mount. Thanks I am gonna check it out. Hey how did you know I had a creeper...lol I just bought one like a few days ago. Quote
Crazy K Posted April 10, 2008 Report Posted April 10, 2008 the stalking continues!!!! the lq1 has three. two for the motor on the left, and one fro the tranny on the right. the other 60degreev6s have two, one for the motor and one for the tranny, on each side. the 3800... don;t know. probably the same as the lq1 Quote
Psych0matt Posted April 10, 2008 Report Posted April 10, 2008 Ken and I just popped my tGP engine back in last weekend. Two mounts underneath; one for the motor, one for the tranny, and two on top (dogbones) Quote
shadow Posted April 10, 2008 Author Report Posted April 10, 2008 Well I looked under the car today and from I can see there is a metal piece on the motor mount and it appears to be welded on..........on one side? I suck at this since I only think I saw one mount. Mechanic shop quoted me at $500.00 per mount went to pepboys and they wanted $450.00 per mount. Quote
shadow Posted April 10, 2008 Author Report Posted April 10, 2008 Ken and I just popped my tGP engine back in last weekend. Two mounts underneath; one for the motor, one for the tranny, and two on top (dogbones) Okay so its one motor mount under and one tranny. Was the Motor mount welded on one side? Quote
ManicMechanic Posted April 10, 2008 Report Posted April 10, 2008 The bracket for the mount is welded to the subframe, the mount is bolted to the bracket. Quote
Psych0matt Posted April 10, 2008 Report Posted April 10, 2008 you unbolt the motor mount from the underneath side, but have to get the mount out of the little cup/bucket thingy from the top, and of course unbolt the other side of the mount from the engine Quote
shadow Posted April 10, 2008 Author Report Posted April 10, 2008 you unbolt the motor mount from the underneath side, but have to get the mount out of the little cup/bucket thingy from the top, and of course unbolt the other side of the mount from the engine Ohh okay but there does not seem to be any space? Do I have to jack up the engine somehow? Quote
Psych0matt Posted April 10, 2008 Report Posted April 10, 2008 You shouldn't. Man, if I would have known about this thread I would have taken some pics the other day. If I had a camera I might even be able to get some now, but I don't have a camera anymore the tranny mount you can get to from the drivers side wheel well, but it doesn't sound like that's what you want to get to. You shouldn't need to jack it up, although if you physically don't fit then you might want to. Should jus be two bolts, on the bottom of an elongated cup shaped thing, I think 15mm (if not then maybe 13). it should be right on the middle of the passenger side subframe rail, on the inside. Quote
Psych0matt Posted April 10, 2008 Report Posted April 10, 2008 Yes, you do. ? I guess I'd have to look at the underside again Quote
