Visually Inspecting Gaskets..
Soo I thought there would be something on this forum about visually looking to see if your gaskets, READ: Intake gasket, had been replaced, but I searched and didn't see anything.
Is there a sure-tell sign of seeing if it has been replaced or not? Feeling if it's plastic or something? Would a replaced one be a different color? (it should be! silly engineers)
Look at the bolts for the valve covers and intake manifold. If they have been off, then you SHOULD see marks from the tools on them. If you can not, then, the probably have not been off. If you pull a valve cover, you should be able to marks on the rocker bolts, too.
My DOHC has had gaskets replaced from the bottom up, the old gasktes were black and the new ones are blue....
New ones where probabaly Fel-Pro then.
As far as intake gaskets, you can't really tell too easily if they have been changed. If you suspect a vacuum leak, get a can of Clean-R-Carb or the equivalent, fire up the engine and spray the stuff around the mating surfaces where the gasket is. If there is a leak, the idle will change.
