rockfangd Posted March 26, 2008 Report Posted March 26, 2008 hi everyone i have been working on a 94 pontiac GP coupe. The window falls forward out of the tracks. sometimes if you hold down on the window at the rear it goes up smooth but if you dont hold the window it slides forward and bam I have tried to tighten the rear track together and the front track also, it seemed to help but i was wrong. So i pulled the window and the window looks normal, maybe its worn but i am just not seeing it. I also tried replacing the front track. tonight i was adjusting the front track and it worked perfect like 10 times so i said good and put the door panel part way on, tried again and it worked great, so i put the panel on completely and tried the window and bam it went right back off the tracks This car has been a thorn that has been busting my balls from a continous door latch problem with many hours of aggrivation, to a busted catch at the front that someone snapped off and now this window Anyone know what is common or a good idea to try or replace. i am up for anything. thanks to all in advance Quote
rockfangd Posted March 30, 2008 Author Report Posted March 30, 2008 well i think i may have fixed the problem by replacing the window itself. so far anyhow Quote
