VATS/Pass Key II Ignition cylinder lubrication
Yes, they got PK2.
Anyways, I had a similar issue happen with my Acura. Some liquid wrench sprayed into the ignition cylinder, and turning the key a few dozen times did the trick.
Mine isn't stuck; its maybe two "stiff" for me. Who knows maybe this is how it should be?
Two questions:
1. Should I lube the ignition cylinder since there are contacts inside of it for the resistor?
2. Should I use graphite or silicone lubricant?
3. My service manual mentions nothing of this.
Well its not broken, but its stiff.
I'm just asking if I should lube it?
............................. I won't sig quote this, but it's just CRYING to be quoted.
I'd say just squirt some Z4 up there. What's it gonna hurt?
I don't want to destroy a non-broken lock cylinder that is probably expensive. What the hell is Z4?
Feel free to quote that, I was typing that and was like this is going to get sigged.
