Crankshaft Positioning Sensor (CKP) Tutorial LX-5 3.5
I can attack this two different ways but I will begin with the W-body rather than the G.
These fail every 6 or 7 years it has nothing to do with mileage for some odd reason. I have replaced them with 20k mile and 250k miles and it seems to be a duration thing rather than distance. They will throw a missfire code or may throw a crank sensor code or both. Wells (Hecho en Mexico) unit availible from Autozone for $58, new GM also (Hecho en Mexico) costs $218.
1. Remove negative battery cable before perfomring ANY electrcial work, then jack vehicle up and support car with jackstands outboard on left and right sides under corners of rear of subframe.
2. Remove plastic inspection cover from starter and transmission (2) 10 mm bolts securing it on, pull down to remove.
3. Remove (2) 15 mm bolts securing starter to front of engine block, you will need to pull starter snout out of recess cut into transaxle towards passenger side of vehicle and manipulate it down between front of subframe, becareful not to drop this unit as its heavy and the ignition wires are no long enough to set starter on ground with out removal.
4. Remove 7 mm bolt securing solenoid wire onto starter/solenoid assembly.
5. Remove 13 mm battery wire from center of solenoid.
6. Set starter/solenoid aside.
7. Crank sensor is located directly above starter unit on front of engine see diagram.
8. Remove crank sensor pigtail it has 4 wires andis a flat harness.
9. Remove 10 mm bolt securing crank sensor.
10. Turn Crank sensor 90 degrees and pull out.
11. Reinstall new sensor plug sensor in, reinstall igntion wires , reinstall starter/solenoid assembly reinstall inspection cover, bring vehicle to floor level.
Many times you can clean the metal shavings off the magnetic plug type pick up and clean oil and grease form it and restore the signal but for my time/money I am buying a new one, or taking one of my 3 that I have purchased from Autrozone back for a free replacement. This job should take 15-20 minutes.
The only thing that differs on the G-body (the Aurora) is there is a plastic coupler that secures the two goodyear air conditioning hoses to the engine block, that assembly must be removed prior to starter removal. Also there is more room between the engine block and the subframe to drop the starter and the ignition wires are longer and meatier than the Intrigue harness.
  • 3 months later...
Awesome write up. :thumbsup: Just did this tonight and it only took about a half hour. The hardest part of the whole job was trying to free up the old sensor from the block. Other then that, went off without a hitch.
I should have mentioned turning the whole sensor 90 degrees aids a great deal in its removal.
Exactly what I did. It was getting it to actually rotate that was the trouble. Once i rotated it, it popped right out.
  • 2 years later...
Wish I knew this before paying 250 dollars to get this part changed (Impala thats 6 years old and has 45k). The car is still throwing a code, so maybe I'll try and put in a new one myself.
  • 4 months later...
will be doing this this up comming weekend! seems simple enought, thanks for the write up
